Todays' project, log splitter mod...
   / Todays' project, log splitter mod... #1
JerryK
Elite Member
Vanderbilt, Michigan, USeh?
Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST(2018)Cub Cadet Pro Z 154L (1991) Caterpillar E70B
I have an old Harbor Freight splitter [ most of my HF stuff was made in Taiwan years ago ] that I usually use vertically, big blocks. ] Today I junked up a tray so I could use it for smaller stuff horizontally. Held on by just one 3/8" bolt on the side.
   / Todays' project, log splitter mod... #2
Looks good and the tray makes it so much easier.
   / Todays' project, log splitter mod... #3
Maybe a long top-link pin, and lynch pin to hold it, would allow you to to a "tool free" swap from vertical to horizontal. I probably would have used two bolts or pins. A pin might rattle unless you get a reasonably tight fit. Did you put a nice radius on the corners of the tray, especially on the working/valve side, to avoid rips in your pants? :)
It looks good and will save a lot bending over no doubt.
I put a 3/4" pin in it soon after, and modified the hyd handle to make it closer. So I did not have to bend over and work the knob... which is more anoying the more you do it. Here is pictures of the hyd operator... lot fun when I caught the fringe on my old shorts on fire welding, and it took me a while to relise it... then beat out the glowing cotten.. :) Did not have the picture of the pin install, but it was just hog'n out a 3/4" hole with my big slow drill...
The tray mod was a slip fit on the three inch wide splitter tube. And if it did rattle, you would never hear it over the racket the B&S makes.. :) I did radius the op side a little, but will radius it more thru the years as I deposit skin and blood on the edge, slowly wearing down the metal to a higly polished state.... again... :) [ IF it last that long, the splitter is twenty years old already... ]
   / Todays' project, log splitter mod... #6
Good job. I like the valve handle extension.
As long as you don't make it just perfect, it will last another 20 years. :laughing: Over-improve it and you are asking for doom.
2014 GOOSENECK DRIVER SIMULATOR TRAILER (A45046)
2014 GOOSENECK...
Motor (A45336)
Motor (A45336)
More info coming soon! (A44572)
More info coming...
Utility Trailer (A45336)
Utility Trailer...
1999 Stoughton Trailers 53ft T/A Enclosed Cargo Trailer (A44571)
1999 Stoughton...
Engine Parts (A47484)
