Toe-In Setting
   / Toe-In Setting #1
bill18163
NW Pennsylvania
Kubota B2710,BX1860,LA3940
I have a L3940 four wheel drive Kubota. I checked the toe-in of the front wheels yesterday and found that they needed adjusting. Toe was "0" to just a little bit "out". Operators manual calls for 1/16" to 5/16" toe-in and the Work Shop Manual calls for .08" to .300" which is approx. the same. The L3940 is adjusted by turning the tie rods on each side. I noticed that there was more thread showing on one side than the other but I accepted that the factory had the original setting correct and went ahead and adjusted both sides equally for a toe-in of 5/32". A question entered my mind later on. Since each wheel is adjusted by its own tie rod, how do you know that each wheel by itself was pointed straight forward with no toe when I first started? I know I got "0" toe-in on my gage when I started but how do you know the two tires were pointing straight forward? Is there a way you could tell if a tire and wheel is pointing straight forward with no toe in relation to the tractor? That way you could set both tires each by itself with "0" toe for a starting position and then adjust each equally to get the necessary toe-in. I know there is a possibility that I am not understanding this whole procedure in regards to the geomertry involved so if there is anybody that has some experience with it please set me straight.
   / Toe-In Setting #2
It has an orbital valve, the steering wheel never centers to the same place. Don't worry too much about the threads, if they are at all close, the tire hits the steering stop long before the ram runs out of travel.
   / Toe-In Setting #3
If the front axle is symmetric and the tierods are the same length, you should expect to have the same number of threads showing on both. Otherwise, the steering gear is not centered and you will have a different turn circle left to right, even thoough the toe is correct. You can also check this with the number of turns of the steering wheel in both directions. Try to do this with the wheels off the ground because the loading on the gear can affect the position control in a power steering valve. To check absolute toe, just measure the forward and rearward lateral locations of the rims. Try to get them at the spindle height if possible.
Tandem Axle Rear Truck Frame (A48081)
Tandem Axle Rear...
2018 Nissan Versa SV Sedan (A48082)
2018 Nissan Versa...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A50397)
Kubota 24in Quick...
2003 Chevrolet Silverado 2500 Pickup Truck (A48081)
2003 Chevrolet...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
