too much oil?
   / too much oil? #1
BrettW
Platinum Member
now in S.C.!!
Yanmar FF205D
I checked my trans oil the other day and it looks like it is too full. I thought I had it right last summer when I filled it. What is the correct way to check it? Do you screw the cap all the way down, or just sit it on the top and check it?
thanks, bw
   / too much oil? #2
It may not be the same on your Yanmar but my JD 750 (made by Yanmar) shop manual says to set the dip stick on threads without screwing in to check level.
   / too much oil?
thanks, it is likely the same. bw
   / too much oil? #4
If it has more oil in it than it did last year, I would start checking.... Oil can leak out.. but if it fills up I would bet there is something else in there displacing it.. like water that leaked past a shifter boot, etc.. or perhaps engine oil.. though I don't know if there is a common seal that will let the engine oil leak into the tranny system...
To check for water, loosen the drain plug if it is at the lowest pint.. the water would collect there, if it isn't emulsified, etc.
soundguy.
   / too much oil?
thanks, 1st i'll make sure I'm on flat ground. the oil looks very clear so hopefully no leaks. I could of just measured it wrong, bw
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52748)
2016 Ford F550 4x4...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2018 Ford F150 XL (A52384)
2018 Ford F150 XL...
2000 INTERNATIONAL 4700 (A52472)
2000 INTERNATIONAL...
2011 JACK  130BBL (A52472)
2011 JACK 130BBL...
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
