toolcat problem I have an error code Work group lockout light on with a code 65-07
   / toolcat problem I have an error code Work group lockout light on with a code 65-07 #1
mcreath
mt airy, md
bobcat toolcat
was wondering if anyone could help me locate problem The code is 65-07 "workgroup lockout solenoid open circuit. Does anybody have any ideas on where to located open circuit. The bucket is down and I can't get it on the trailer to move to dealer. hydraulics work. thnaks Mike creath
   / toolcat problem I have an error code Work group lockout light on with a code 65-07 #2
You will need to tell us what production version (A,B,C,D, or F) you have. If not sure give the first 4 digits of the serial number. The manifold block that has the workgroup solenoid on it has been installed in different locations on some versions.
Serial # is 424711184 thanks
   / toolcat problem I have an error code Work group lockout light on with a code 65-07 #4
This is a B series if anyone ever asks again. The solenoid block with the lockout solenoid is under the passenger seat. If it hasn't been tampered with it will have a grean zip tie strap on it. 12 volt power wire going to it is #4410. Solenoid ohm resistance should be around 11 ohm.
Thanks for the help. It was the corroded plug going to the solenoid. it's the first one from the back of the unit. thanks again.
   / toolcat problem I have an error code Work group lockout light on with a code 65-07 #6
I have a toolcat (Series D?)
S/N 520512184
and can't find the workgroup lockout solenoid (code 65-06) ....been spending hours looking for it, I found the 4410 wire.
Any lead on this appreciated
   / toolcat problem I have an error code Work group lockout light on with a code 65-07 #7
fbitz, any update on your error code problem?
   / toolcat problem I have an error code Work group lockout light on with a code 65-07 #8
YES!
After I had exhausted all possible locations I removed the bottom steel plate than runs across the middle front of chassis and found 4 pilot valves with the
correct number...Found that solenoid was cracked and shorted. This happened after someone power washed my machine so maybe the cold water on a hot
surface did that.
Anyhow I ended switching the differential lock solenoid to the work group lock for now ...I am not sure I have ever used the Diff Lock anyhow.
I am afraid the solenoid replacement will be expensive as usual with parts at BobCat.
   / toolcat problem I have an error code Work group lockout light on with a code 65-07 #9
Hi! Fault codes for Bobcat, if somebody needs :)
Code Description
01-16 air filter Not connected
01-17 Clogged air filter
02-16 No hydraulic discharge filter is connected
02-17 Clogged Hydraulic Discharge Filter
03-09 Low battery voltage
03-10 High Voltage battery
03-11 Extremely high battery voltage
03-14 Extremely low battery voltage
03-22 The battery voltage is below the maximum permissible
04-09 Low oil pressure in the engine
04-14 Extreme hHibiscus oil pressure level in the engine
04-15 Engine oil pressure at emergency shutdown level
04-21 The oil pressure in the engine is above the maximum permissible
04-22 The oil pressure in the engine is below the maximum permissible
05-09 Low recharge pressure in the hydraulic system
05-14 Extremely low recharge pressure in the hydraulic system
05-15 Recharge pressure in the hydraulic system at the level of emergency shutdown of the engine
05-21 The recharge pressure in the hydraulic system is higher than the maximum
05-22 The recharge pressure in the hydraulic system is below the maximum permissible
06-10 High engine speed
06-11 Extremely high engine speed
06-13 No engine speed signal
06-15 Engine speed at the emergency shutdown level
06-18 Engine speed outside the permissible limits
07-10 High oil temperature in the hydraulic system
07-11 Extremely high oil temperature in the hydraulic system
07-15 Oil temperature in the hydraulic system at the level of emergency shutdown of the engine
07-21 The oil temperature in the hydraulic system is higher than the maximum permissible
07-22 The oil temperature in the hydraulic system is below the maximum permissible
08-10 High temperature of engine coolant
08-11 Extremely high engine coolant temperature
08-15 Engine coolant temperature at the emergency shutdown level
08-21 The coolant temperature of the engine is above the maximum permissible
08-22 The coolant temperature of the engine is below the maximum permissible
09-09 Low fuel level
09-21 The fuel level is above the maximum permissible
09-22 The fuel level is below the maximum permissible
11-05 The safety frame sensor is closed to the battery
11-06 The security frame sensor is closed to mass
12-21 Signal PWM Controller front additional. Hydraulics at the upper limit of the range
12-22 PWM Controller front additional. Hydraulics at the lower limit of the range
12-23 PWM Controller front additional. Hydraulics are not in a neutral position
13-05 The retaining solenoid of the fuel cutoff is closed on the battery
13-06 The retaining solenoid of the fuel cutoff is closed to the mass
13-07 Circuit Break solenoid cutoff fuel
14-02 Motorcyclist the fuel cutoff solenoid, erroneous switching on
14-03 Motorcyclist the fuel cutoff solenoid, erroneous shutdown
15-02 Motorcyclist solenoid lock thrust, erroneous inclusion
15-03 Motorcyclist solenoid lock thrust, erroneous shutdown
16-05 The holding solenoid lock is closed on the battery
16-06 The holding solenoid of the thrust lock is closed to the mass
16-07 Tearing chain restraint solenoid lock thrust
17-05 The hydraulic valve solenoid is closed to the battery
17-06 The hydraulic valve solenoid is closed to the mass
17-07 Rupture of the solenoid circuit of the hydraulic shutoff valve
18-05 The spool solenoid is closed on the battery
18-06 The spool solenoid is closed to the mass
18-07 Spool solenoid circuit break
19-02 Bucket positioning solenoid, erroneous switching on
19-03 Bucket positioning solenoid, erroneous shutdown
20-02 Speed switching solenoid, erroneous switching on
20-03 Speed switch solenoid, erroneous shutdown
21-02 Glow plugs, erroneous inclusion
21-03 Glow plugs, erroneous shutdown
22-02 Starter, erroneous inclusion
22-03 Starter, erroneous shutdown
23-02 Rear base solenoid, erroneous switching on
23-03 Rear base solenoid, erroneous shutdown
24-02 Rear Pull Solenoid, erroneous switching on
24-03 Rear Pull Solenoid, erroneous shutdown
25-02 Rear auxiliary proportional solenoid, erroneous inclusion
25-03 Rear auxiliary proportional solenoid, erroneous shutdown
26-02 Erroneous inclusion of the front base solenoid
26-03 Erroneous shutdown of the front base solenoid
27-02 Erroneous inclusion of the front Stock Solenoid
27-03 Erroneous shutdown of the front Stock Solenoid
28-02 Erroneous inclusion of solenoid Divertera
28-03 Incorrect solenoid shutdown Divertera
29-02 Large feed solenoid, erroneous switching on
29-03 Large feed solenoid, erroneous shutdown
30-28 Controller memory failure
31-28 Recovery mode failure
32-04 Advanced Management (ACS) is not reported to the controller Bobcat
32-23 ACS Advanced Management Not calibrated
32-31 Failure of the actuating mechanism of inclination
32-32 Malfunction of the electrical wiring of the actuating mechanism of inclination
32-33 Failure of the electrical wiring of the bucket tilting handle
32-34 Executive tilting mechanism not in neutral position
32-35 Handle/Bucket tilt pedal not in neutral position
32-36 Failure of the actuating mechanism of lifting
32-37 Malfunction of electrical wiring of the actuating mechanism of lifting
32-38 Failure of the electrical wiring of the boom handle
32-39 Executive lifting mechanism not in neutral position
32-40 Arm/Boom lift pedal not in neutral position
32-41 No connection
32-49 Executive lifting mechanism closed to mass
32-50 The executive tilting mechanism is closed to mass
32-51 Actuator lifting mechanism closed on the battery
32-52 The actuator tilting mechanism is closed to the battery
32-53 Handle/Boom lift pedal closed to mass
32-54 Handle/Bucket tilt pedal closed to mass
32-55 Arm/Boom lift pedal closed on battery
32-56 The handle/bucket tilt pedal is closed to the battery
32-57 Reduced performance of the lifting actuation mechanism
32-58 Reduced performance of the executive tilt mechanism
32-59 Wrong direction of the actuating mechanism of lifting
32-60 Wrong direction of the executive tilt mechanism
32-61 The lock of arms is closed to mass
32-62 The lock of Arms is closed on the battery
32-63 The chain of locking pedals is closed to the mass
32-64 The chain of locking pedals is closed to the battery
32-65 Sensor supply voltage outside the permissible limits
32-66 Battery voltage out of the allowable limits
32-67 Switched during Operation
32-68 Boom Boom ARM Information error
32-69 The switch of control modes has switched during operation
32-70 The chain of the right handle of motion is closed to mass
32-71 Circuit of the right handle of movement is closed on the battery
33-23 Main controller (Controller Bobcat) Not programmed
34-04 The keypad with a button run is not reported to the controller Bobcat
35-02 Speed fan switch, erroneous switching on
35-03 Speed fan switch, erroneous shutdown
36-48 Multiple ACD controllers are connected
37-02 Speed additional speed switch, erroneous switching on
37-03 Speed additional speed switch, erroneous shutdown
Bobcat Medium-S630
Bobcat Medium-S630
38-04 No connection to Joystick controller
38-05 The x-axis of the left joystick is not in a neutral position
38-06 The X-axis of the right joystick is not in a neutral position
38-07 The Y-axis of the left joystick is not in a neutral position
38-08 The Y-axis of the right joystick is not in a neutral position
38-09 Control mode switch-circuit to the battery or to the mass
38-11 Executive lifting mechanism not in neutral position
38-12 Executive tilting mechanism not in neutral position
38-13 Failure of the actuating mechanism of lifting
38-14 Failure of the actuating mechanism of inclination
38-15 Right Wheel speed control failure
38-16 Faulty wiring for the speed of the left wheel
38-17 Reduced performance of the executive tilt mechanism
38-18 Reduced performance of the lifting actuation mechanism
38-19 The X-axis of the left joystick, behind the upper bound of the range
38-20 X-axis of the right joystick, beyond the lower bound of the range
38-21 The Y-axis of the left joystick, behind the upper bound of the range
38-22 The Y-axis of the right joystick, behind the upper bound of the range
38-23 Signal of the front right control sensor outside the upper boundary of the range
38-24 Signal of the front left control sensor at the upper limit of the range
38-25 Signal of the rear right control sensor at the upper limit of the range
38-26 Signal of the rear left control sensor at the upper limit of the range
38-27 Signal of the actuating mechanism of lifting at the upper boundary of the range
38-28 Signal of the executive mechanism of inclination at the upper boundary of the range
38-29 X-axis of the left joystick, behind the lower bound of the range
38-30 X-axis of the right joystick, beyond the lower bound of the range
38-31 Y-axis of the left joystick, beyond the lower bound of the range
38-32 Y-axis of the right joystick, beyond the lower bound of the range
38-33 Signal of the front right control sensor at the lower limit of the range
38-34 Signal of the front left control sensor at the lower limit of the range
38-35 Signal of the rear right control sensor at the lower limit of the range
38-36 Signal of the rear left control sensor at the lower limit of the range
38-37 Power supply “1” 5-volt sensor, behind the lower boundary of the range
38-38 Power supply “2” 5-volt sensor, behind the lower boundary of the range
38-39 Executive lifting mechanism closed to mass/beyond the lower boundary of the range
38-40 The executive tilt mechanism is closed to the mass/signal at the lower limit of the range
38-41 Wrong direction of the executive tilt mechanism
38-42 Wrong direction of the actuating mechanism of lifting
38-43 The solenoid of the left front drive, erroneous switching on
38-44 Solenoid of left reversible drive, erroneous switching on
38-45 Right front drive solenoid, erroneous switching on
38-46 Right reverse actuator solenoid, erroneous switching on
38-47 Front right control solenoid, erroneous switching on
38-48 Front left solenoid control, erroneous switching on
38-49 Rear right control solenoid, erroneous switching on
38-50 Rear left solenoid control, erroneous switching on
38-51 Control system pressure solenoid, erroneous switching on
38-52 Reversing signal, erroneous switching on
38-53 Left Front drive solenoid, erroneous shutdown
38-54 Solenoid of left reversible drive, erroneous shutdown
38-55 Right front drive solenoid, erroneous shutdown
38-56 Right reverse actuator solenoid, erroneous shutdown
38-57 Front right extension control solenoid, erroneous shutdown
38-58 Front right retraction control solenoid, erroneous shutdown
38-59 Front left solenoid of extension control, erroneous shutdown
38-60 Front left solenoid control retraction, erroneous shutdown
38-61 Rear right extension control solenoid, erroneous shutdown
38-62 Rear right retraction control solenoid, erroneous shutdown
38-63 Rear left solenoid control, erroneous shutdown
38-64 Rear left solenoid control retraction, erroneous shutdown
38-65 Control system pressure solenoid, erroneous shutdown
38-66 Reversing signal, erroneous shutdown
38-67 No messages from controller Bobcat
38-68 Wheel setting angles (alignment) not calibrated
38-69 actuating mechanisms of lifting and tilting are not calibrated
38-70 Power off
38-71 Battery voltage outside the permissible limits
38-72 Drive Pump Not calibrated
38-73 Control/Motion mode switch is switched on during operation
38-74 Speed of the uncontrolled right wheel, erroneous switching on
38-75 Speed of uncontrolled left wheel, erroneous switching on
38-76 Control system pressure solenoid-insufficient current
38-77 Front right extension control solenoid-insufficient current
38-78 Front right retraction control solenoid-insufficient current
38-79 Forward left solenoid of extension control-insufficient current
38-80 Front left solenoid control retraction-insufficient current
38-81 Rear right extension control solenoid-insufficient current
38-82 Rear right retraction control solenoid-insufficient current
38-83 Rear left solenoid control-insufficient current
38-84 Rear left solenoid control retraction-insufficient current
38-85 Power supply “1” 5-volt sensor outside the upper boundary of the range
38-86 Power supply “2” 5-volt sensor outside the upper boundary of the range
38-87 Right front wheel lock (mechanical malfunction control)
38-88 Locking of the Left front wheel (mechanical malfunction control)
38-89 Right rear wheel lock (mechanical malfunction control)
38-90 Rear left control error
38-91 There are no pulses of the right wheel speed sensor
38-92 There are no pulses of the left wheel speed sensor
38-93 Right wheel speed sensor does not respond
38-94 The left wheel speed sensor does not respond
38-98 Controller in the drive calibration mode
38-99 Controller in wheel position calibration mode
45-03 Right turn pointer, erroneous shutdown
46-02 Left turn pointer, erroneous inclusion
46-03 Left turn pointer, erroneous shutdown
47-21 Power supply of 8-volt sensor at the upper limit of the range
47-22 Power supply of 8-volt sensor, behind the lower boundary of the range
48-02 Front light relays, erroneous switching on
48-03 Front light relay, erroneous shutdown
49-02 Rear light relay, erroneous switching on
49-03 Rear light relay, erroneous shutdown
60-21 Signal of the control lever of the back additional Hydraulics at the top of the range
60-22 Signal of the control lever of the back additional Hydraulics at the lower limit of the range
60-23 Control lever of the back additional The hydraulics are not returned to the neutral position
64-02 Failure to turn on the power relay
64-03 Erroneous shutdown of power relay
74-72 Controller boot code failed Bobcat
74-73 Left panel, receiving device error
80-02 ACD, Exit “A”, erroneous switching on
80-03 ACD, Exit “A”, erroneous shutdown
81-02 ACD, Output “B”, erroneous switching on
81-03 ACD, Exit “B”, erroneous shutdown
82-02 ACD, Exit “C”, erroneous inclusion
82-03 ACD, Exit “C”, erroneous shutdown
83-02 ACD, Exit “D”, erroneous switching on
83-03 ACD, Exit “D”, erroneous shutdown
84-02 ACD, Output “E”, erroneous switching on
84-03 ACD, Exit “E”, erroneous shutdown
90-02 Service exit “C”, erroneous switching on
90-03 Service exit “C”, erroneous shutdown
91-02 Service exit “D”, erroneous switching on
91-03 Service exit “D”, erroneous shutdown
92-02 Service exit “E”, erroneous inclusion
92-03 Service Output “E”, erroneous shutdown
93-02 Service exit “F”, erroneous switching on
93-03 Service exit “F”, erroneous shutdown
LOT LOCATIONS (A51219)
2020 Caterpillar 302.7D Mini Excavator (A51242)
2020 Caterpillar...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
SERVICE BODY BED W/CRANE (A50854)
SERVICE BODY BED...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
John Deere 946 Center Pivot Rotary Mower-Conditioner (A51039)
John Deere 946...
