Tires tools to fill tires.
   / tools to fill tires. #1
gregp
Bronze Member
I want to fill the tires of my TC24DA with rv anti freeze. The 50 below zero stuff. Where can i get the tools to do this with. I believe there is some sort of drill attachment and an adaptor to fit on the valve stem. Thanks for the help.
   / tools to fill tires. #2
</font><font color="blue" class="small">( I want to fill the tires of my TC24DA with rv anti freeze. The 50 below zero stuff. Where can i get the tools to do this with. I believe there is some sort of drill attachment and an adaptor to fit on the valve stem. Thanks for the help. )</font>
You can get a small pump (drill-driven) at WalMart, but I prefer something a little more substancial. I got a Teel chemical pump from W.W. Grainger. It has a replacable rubber coated impeller (comes with 2 extras. I've done dozens of tires and never needed one yet) Pump body is stainless steel. Holds up well to most anything you'll encounter in a tractor tire. Cost was about $65 if I remember correctly.
Schraeder valve adapter is available through NAPA. They have 2 models. One is more of a thing you'd find at a professional tire shop. It screws on the stem, then turns the core out without loosing any fluid (in an already filled tire) It was almost $200. They have a cheaper version. It was about $25. An empty barrel, a couple pieces of garden hose, and you're in business.
I put together a "kit" to do my tires. Pump, valve, hoses, valve core tool, and extention cord, all packed in a dedicated tool box. I spent about $125. Like I said, I've done MANY tires. Much more convenient that hauling to the tire shop. Also, by having everything, when you get a rear flat, you can pump most of the fluid out and save it, before it all runs out on the ground.
   / tools to fill tires. #3
I've left jugs of rv antifreeze sitting out in the winter and it does freeze solid in subzero weather. I didn't notice any expansion however, so that may be where the pipe protection is. You just might want to do a little research before you go that route.
   / tools to fill tires. #4
I just got through with filling my tires. You want to check out this thread:
Link
I don't have as much experience as farmwithjunk, but I did buy a conventional tool at Napa ($4.95) and a filler cap that fits anti-freeze bottles (.75 cents) and a hose fitting ($1.75) to use them together as in the thread. Got great results with very little spillage.
MikePA: Please review your message before posting it. It's simple not to create a long link that widens the entire thread. Just insert a descriptive word or two between the {url=http://whatever}<font color="red">Enter words here</font>{/url} instead of the entire URL. Replace parentheses {} with square brackets in previous example. Alternatively, if you use the Instant Markup language URL link, the first prompt is for the URL. The second prompt is for a description. Do not simply paste in the URL again. Type a short description of the link.
   / tools to fill tires. #6
I got one of those little kits at Tractor Supply to fill my tires(less than $10). The way I got the antifreeze into the tire was I got a 50' water hose and drained it. Connected it to my water faucet and let it run a little just to get a little water in the hose. At the other end of the hose I took a funnel and poured the antifreeze into the hose. When the hose fills up, I connect it to the tire valve kit from TSC and turn on the faucet. I let it run for a while so all the antifreeze empties into the tire. If you can't empy the 1 gallon jug of antifreeze into the hose the first time, just empty the hose and repeat the process. I believe I got the whole jug in one run though. It is a little work, but it's not something done real often and it sure is cheap. /forums/images/graemlins/grin.gif I put one gallon of antifreeze in each tire. doesn't get very cold where I'm at though, so just check what mixture you'll need for your tire capacity.
   / tools to fill tires. #7
Ok, I did a little research myself on rv antifreeze cause I've been wondering about it's freeze protection. I have the Traveller brand sold at TSC, and it says burst protection to minus 50, not freeze protection. I looked up some manufacturers online, and the formula seems to be 61% distilled water, and 39 % polypropylene glycol. So today I took a cup of it and stuck it in my freezer for a couple of hours, turned to icy slush. I don't know where you live greg, but if you have temps like we do around here, I'd use something else.
I live in Alaska. Can i interpret burst protection to mean that it may get slushy but it wont freeze and expand? Would i need total freeze protection? Our average winter temperature is around 20 above with a few days getting -20 or so. That is why i figured -50 rv anti freeze would be a good bet.
   / tools to fill tires. #9
I'm not sure what to think. I know that jug I left out last winter was froze solid as a rock, with no expansion. I think it was 10 below that day. My opinion, polypropyline glycol will work, just needs to be at a higher concentration than what rv antifreeze uses.
2019 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2019 Chevrolet...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
2021 Fleco DX140 24in Tooth Bucket Excavator Attachment (A49461)
2021 Fleco DX140...
100 GAL FUEL TANK (A50854)
100 GAL FUEL TANK...
Tennant S30 Ride-On Sweeper (A49346)
Tennant S30...
