Toothbar or No Toothbar?
/ Toothbar or No Toothbar? #1
ymarianne
catskills in upstate NY
2008 MF 1531
What's the upside/downside of getting a toothbar on my FEL? Also, do most people have bucket hooks? They seem like a no brainer. Thanks.
/ Toothbar or No Toothbar? #2
Up side (for me):
  • strengthen leading edge of bucket
  • able to break into rock piles (or frozen piles)
  • Can tear sod (to a shallow depth)
Down side: haven't personally found any. But I can imagine it would be inconvenient to have to remove toothbar to use another bucket accessory (like pallet forks or bale spear).
//greg//
/ Toothbar or No Toothbar? #3
Having a BH attachment I see no benefit of a toothbar but I do see drawbacks with leveling material with a toothbar.
The problem with a BH attachment is it is a chick magnet.:D
/ Toothbar or No Toothbar? #4
I built a toothbar for my bucket last year, I'll never be with out one again. I built it to use the factory holes on my John Deere bucket but I've never taken it off since installed. It's great for hay laden manure, cleaning up brush from a downed tree, digging into clay, and the list goes on. Haven't had a down side yet. I can see where back blading to smooth an area wouldn't work to well, but I don't do that enough worry about. Almost forgot, I did put chain hooks on the bucket near the factory reinforcements. I made the mistake on my first tractor of using a large slip hook off a broken log chain, it's what I had around, that was a mistake because you couldn't just drop the chain on the hook and it stay. On my second tractor I welded two chain hooks, one on either side, the standard kind that the chain won't slip through, much more useful.
/ Toothbar or No Toothbar? #5
I got one last year after putting it off for quite awhile - definitely worth it. I have a backhoe too but it is nice to need it a little less. As for leveling, can be done with the heel of the bucket and that is probably better for the loader anyway. I take it off in the winter since the loader is part of my snow removal process. Takes 10 minutes to remove/replace the toothbar.
/ Toothbar or No Toothbar? #6
1*
2*
1&2*
What with owning both a BH and a Tiller I see no need for a tooth bar.
/ Toothbar or No Toothbar? #7
With owning most attachments known to man and the number of tractors used as an implement in itself, your opinion does not count.;)
/ Toothbar or No Toothbar? #8
Never used a tooth bar. I have a bolt on cutting blade on my bucket. It strengthens and protects the front edge. I do a lot of leveling by back dragging and the bolt on blade works well for that. The rippers on a box blade are probably the next best things for loosening soil when doing loader work.
Bucket hooks are a given. Handiest things next to a sky hook.:)
/ Toothbar or No Toothbar? #9
I use the bucket hooks a lot.
I though I would need a tooth bar, but that idea has faded. The ground I dig in just isn't that hard.
/ Toothbar or No Toothbar? #10
I use a Markham removeable tooth bar, it only takes about 10 min to remove or install. When driving into a pile of clay dirt with the bucket it is like having 30-50% more horse power because all of the force is concentraited on the small sharp tooth ends. I can still grade using the back edge of the bucket. I take the tooth bar off to scoop loose dirt or rock off of a lawn that I don't want to tear up. I also take it off for snow removal.
Bucket hooks are great, use them alot. There are tons of threads on these forums about the best way to attach or space bucket hooks. Good Luck!
/ Toothbar or No Toothbar? #11
I have a small JD2305tlb and I thought long about adding a toothbar, since I like the finished look after backdragging I was reluctant and didn't think I could get the result I wanted with the toothbar on.Then I began a road/trail project that involved digging shale with large rocks embedded. The toothbar has proven its worth and is very helpful in breaking up the shale as it approaches from below and can sometimes get under a slab where the backhoe cannot. It makes my small machine more effective and is easier on me and my tractor. I have since learned to smooth using the heel of the bucket, takes a little practice. I keep the toothbar on all the time now. Hope this helps. Mark
/ Toothbar or No Toothbar? #12
I don't know about on a FEL but on my skidloader a the tooth bucket made it a completely different machine. Hard dirt, soft dirt, backdragging, digging rocky soil, mud, it is all better with the tooth bucket.
I wouldn't/couldn't be without one.
/ Toothbar or No Toothbar? #14
One of the best things I've bought for my tractor. Turned it into a dirt digging, root grubbing machine!:D
Don
/ Toothbar or No Toothbar? #15
I just finished my Tooth bar today. I always wondered if I needed it. My first dig into the ground pulled up my sprinkler lines.:( So I guess it works good.
/ Toothbar or No Toothbar? #16
I bought my BX2350 a year ago. Even before delivery I asked the dealer to weld two grab hooks on each end of the loader. They are the cheapest attachments I've made to the CUT.
But for the most useful, my vote is a tooth bar. I tried to find an easy way to buy a W.R. Long, but in the end I bought from Markham. No regrets. None. Whether you make one for yourself or buy one, just do it. It can be remove it in no time, but truth to tell I haven't had the need.
I'll probably remove it in late fall when I mount my Loftness 3ph snow thrower and wait for the white stuff.
Doug
/ Toothbar or No Toothbar? #18
after doing some hard digging without it, I noticed the bucket starting to bend; I got a toothbar, and due to the slight bend it the lip it was a bit difficult to install, so I hesitate to remove it. If you do a lot of soft digging, scooping on cement, and leveling I wouldn't use one
Thanks for all your input. Based on your replies and pix, I'll be getting a removable Markham toothbar and hooks. I'll get 2 hooks; from your picture, looks like they are positioned just outside the FEL arms. Rather than get just one, which I thought was all I needed, till I looked at the picture and figured 2 were alot better for stability and strength. Thanks again. This site is so valuable!
/ Toothbar or No Toothbar? #20
Looks like just a couple more things that I need to get. Where were all you guys while I was working up my shopping list last month? Oh ya... you guys were all here and I was the one not here... GEESH!
At least I was smart enough to get the heavy duty box scraper.
(2) STAINLESS STEEL SINKS (A63745)
(2) STAINLESS...
2014 FREIGHTLINER CASCADIA CA113DC T/A 6X4 DAY CAB TRUCK TRACTOR (A59910)
2014 FREIGHTLINER...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2015 CHEVROLET 3500HD FLATBED TRUCK (A63290)
2015 CHEVROLET...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
78" X 15' SHOPBUILT DBL AXLE TRAILER (A63745)
78" X 15'...
