Toothbar
   / Toothbar #1
Anonymous Poster
Epic Contributor
I was looking for a toothbar for my 73'' hd john deere bucket
on my 460 loader, where and how much do they run?
   / Toothbar #2
Sam,
Check out Carver Equipment at www.carverequipment.com. Steve has all the information you're looking for with specs, graphics, and prices. He also appears to have a good reputation with TBNers on price and service.
   / Toothbar
<A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=jdown&Number=77492&Search=true&Forum=All_Forums&Words=<b><i>toothbar</i></b>&Match=Entire%20Phrase&Searchpage=0&Limit=25&Old=1month&Main=75543>Picture of my Toothbar for 73” JD Bucket</A>
K.C. Canary-Fultonville, Inc.
Route 5S
Fultonville, NY 12072
Phone: (518) 853-3405
Toll Free: (800) 920-7097
Fax: (518) 853-3405
Toothbar for your John Deere 460 loader and for any competitors unit.
Ask for Mark in Sales.
   / Toothbar #4
got my tooth bar from carver, good price and fast delivery.
   / Toothbar #5
I want to order a toothbar but I have a question as to the measurements. On my bucket(Kubota) what is the measurements that are required? How close are the toothbars made as far as clearance? There is a pie shape in the front lower cornors that can vary from 59 1/4 (inside) to 58 1/2 (outside) depending as to where the measurement is taken. Which one do they require?
   / Toothbar #6
The interior measurement is important in that it allows the bolts to hold the bar from coming off particularly when going in reverse. The actual mechanism for holding the bar onto the bucket while digging is the front lip of the bucket. The tooth bar will slide over this lip at each tooth and hold it tightly in place, sort of like a slip-on or wedge. The width will be slightly less then the inside width of the bucket so it can be put on or taken off without to much effort. It will extend into the bucket where it bolts on about 5" or so. Measure the narrowest point back to there and get that. Its not critical to get it any closer then about 1/8", Rat...
   / Toothbar #7
On my bucket at the lower cornors(sides) there is a wedge(indent) that is about 1 1/2" high by 5" long. I take it that I do not measure into this wedge. I measure outside of this area which will give me a smaller measurement.
   / Toothbar #8
measure the interior width of your bucket, about 4 or 5 in. in from the cutting edge.this should be what u need for a proper fit.
   / Toothbar
<A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=jdown&Number=41683&page=0&view=collapsed&sb=5&o=&vc=1#Post41683>Toothbar Measurements...</A>
   / Toothbar #10
Sam,
I got mine from K.C. Canary-Fultonville. I had it at my house within three weeks.
Make sure your measurements are good. Just like working with wood, measure twice.
I somehow screwed up my measurements and the toothbar was about 3/4 inches shorter than I needed. So I had to have shims made up to make up the difference. Not a big deal, but an inconvenience.
Terry
2018 John Deere 1653 (A55302)
2018 John Deere...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2025 Unused LandHero LDH-T460XX Mini Skid Steer (A52377)
2025 Unused...
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
Duetz Power Unit (A50120)
Duetz Power Unit...
