3-Point Hitch Top and tilt
   / Top and tilt #1
blake037374
Baton Rouge, LA
CT440
Any body have any suggestions for top and tilt kits? I have a bobcat ct440 I checked bobcat dealer for rear remote setup but it puts the handles next to my right leg and don't really like that by my leg. I saw someone that mounted valve for it next to seat
   / Top and tilt #2
I believe that those control levers can be modified to get them away from being so close to your leg, and that is what I would do. As far as the actual "T&T" set, (cylinders, hoses, QDs, flow restrictors) you would be looking at $635 + shipping if you get them from me. If you want to go after market valves, I can set you up with a 2 spool set for $755, but recommend the 3 spool for $890.
Email me if you are interested. ;)
   / Top and tilt #4
You have pictures of your control valves?
These are what I sell. Made in Germany. The guy that installed that loader valve on the right side of his seat next to the fender has been having some problems with the valve.:( To bad too, he did a GREAT installation of that whole setup. :thumbsup:
   / Top and tilt
I see most with box blade. I'm assuming you can still bushhog with it
   / Top and tilt #7
What problems was he having?
Major internal leakage and it was starting to look like it was at a rate of what the manufacturer was saying was acceptable. :eek: So the hydraulic cylinders were dropping at a rate that was really unacceptable to be properly used. :(
Yes, all normal 3pt work should be able to be performed.
2018 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2018 VOLVO VNL...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52128)
2006 Magnolia Dry...
2000 Genie Man Lift (A50322)
2000 Genie Man...
2004 Dodge Ram 1500 SLT Crew Cab Pickup Truck (A50323)
2004 Dodge Ram...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
(INOP) VOLVO L110H WHEEL LOADER (A50459)
(INOP) VOLVO L110H...
