Topper aft wheel?
   / Topper aft wheel? #1
Anonymous Poster
Epic Contributor
Hi all sorry for this newbie question but I need to know what the rear wheel actually does? I have just bought a 4' topper (brush hog as you call it) this model to be precise (SG 120)
http://www.suire.com/img/machines/stargreen.jpg
It has a rear wheel as an optional extra. I cut 5 acres of mostly level paddocks, however I do have a few banks and unlevel bits to cut also and I have to do quite a lot of sharp turns. Do I need the wheel?
Thanks in advance
Drew
   / Topper aft wheel? #2
The rear wheel is quite useful for maintaining an semieven cut over even slightly uneven terrain.
   / Topper aft wheel? #3
Need it? No. Want it before you try bush hogging the second time? YES!
   / Topper aft wheel? #4
Without a rear wheel, when you start up an incline, the rear of the cutter will hit the ground and the blades will most likely gouge out an area of turf. The rear wheel helps maintain a more level cut.
   / Topper aft wheel? #5
Thanks guys, I will be adding one soon I think, even if it is £130 :(
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
Killbros 260 Seed Conveyor (A52128)
Killbros 260 Seed...
2016 CATERPILLAR 239D SKID STEER (A51242)
2016 CATERPILLAR...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,000LB Crane Service Truck (A50323)
2014 Ford F-550...
Case Ih 1660 Combine (A50514)
Case Ih 1660...
