torch guide advise
   / torch guide advise #1
deereman75
Veteran Member
canada
Deere 2120, Warner & Swasey 6000# offroad forklift, Case W9B loader, various non-running decorations
Well after trying to freehand a torch cut yesterday for some coupons. (read only perfect one was the one done with a grinder) I decided I need to make a guide for it. I have seen on weldingtipsandtricks clamping a piece of angle on, and running the side of the tip against it. I am wondering if I should pick a size, so I can run the nut on the torch along the top edge of the angle, and that will also keep the perfect distance from the work. Is that a good idea? Can it hurt my torch? Is it worth it?
   / torch guide advise #2
I've seen guys do that. Also seen guys use a hose clamp on the cutting tip, place the clamp where the screw is on one side or the other so it can run a long the top toe of the angle iron.
Make sure you sand the top toe of the angle iron with some real fine sanding paper / disc, and before each use rub some soap stone a long the toe also.
   / torch guide advise #3
Great pointers there, Thanks! :thumbsup:
   / torch guide advise #4
My instructor puts his left hand/arm under the torch as a guide/assist. It seems to work for him.
RC
   / torch guide advise #5
i have used angle iron on cuts that need to be right.
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
UNUSED CFG H15R EXCAVATOR (A51247)
UNUSED CFG H15R...
UNUSED FUTURE FT-BC63 63" HYD BRUSH CUTTER (A51248)
UNUSED FUTURE...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
FRONTIER WR3210 LOT IDENTIFIER 108 (A53084)
FRONTIER WR3210...
KUBOTA M7-132 (A53084)
