Toro 217-d
   / Toro 217-d #1
Pauljh
217-d toro groundmaster
Hi just picked up a 217-d black smoke when cranking but doesn’t want to start. New glow plugs air filter fresh fuel started when I bought it after long cranking and then smoke cleared up and ran great but now I can’t get it to start again any help would be much appreciated! Thank you
   / Toro 217-d #2
Sounds like a clogged Injector.
Pull the injector out and reconnect it to the fuel line outside the engine. Stay away from the injector and crank the engine to see if a fine mist is emitted. If it just spirts it's a worn injector.
   / Toro 217-d
Thank you very much I’ll give that a shot tomorrow. I have a ultrasonic cleaner maybe I should pull them out and run them through it.
   / Toro 217-d
Tried testing them on engine they shoot a straight stream more less not a mist
   / Toro 217-d
I’m thinking injector pump is out of time I tried the manual but not making sense to me not sure on alignment markings anyone have an idea about this thank you
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A55787)
BrushFox XHD-78HF...
76in Fork Extensions (A52378)
76in Fork...
