Toro Timecutter 17-42 PTO Removal
   / Toro Timecutter 17-42 PTO Removal #1
makoshako
Hey Guys,
Been a while since I have posted ... I now have a Toro Timecutter 17-42 Zero Turn that our neighbors gave us an I am suspicious that the rings are shot. I need to take the motor off even if I replace it with new. I thought I would look at the old motor to see if it was serviceable, but can't figure out how to get the PTO off ... I have the big *** bolt out, but don't know how to proceed ... any advice?
Thanks in advance.
   / Toro Timecutter 17-42 PTO Removal #2
You might be able to get a service manual online here.
Thanks Bird,
I had just found that and the service manual is useful, but in the area where they are talking about the PTO, they just say take the bolt out and then remove the PTO ... not that simple in mine since it is probably stuck on there. I was wondering if there were any useful tricks for the stuborn PTO. Also after removing the bolt there is large "bolt" ... I put quotes around bolt because it only has 2 sides on it ... and it is not talked about in the service manual (e.g. no instructions to remove it or turn it) ...
Not the best picture, but gives you and idea.
   / Toro Timecutter 17-42 PTO Removal #4
Afraid I can't help you with that; just don't know.
Well I got the PTO out with the help of some penetrating oil, a large screw driver (pry bar) and a ball peen hammer (to jar it some). Now I have the motor off and was able to compression test the motor, but I am only getting 30 PSI. I am assuming that I have bad rings at this point ... the next challenge is to get the "drive" pulley off. It is stuck on too ... the service manual is silent on this.
Any advice here?
2017 Snapper Pro 48in Zero Turn Commercial Mower (A51691)
2017 Snapper Pro...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
HLA 2500 8' Snow Pusher Bucket (A52349)
HLA 2500 8' Snow...
2017 HINO BOX TRUCK (A52576)
2017 HINO BOX...
