Toro ZX440 ZTR or JD X304 4WS?
   / Toro ZX440 ZTR or JD X304 4WS? #1
Ken_CT
CT
BX23, Hustler Mini Fastrak 42 w/mulch kit, Wheel Horse 14-38XL
Hi,
I have a Kubota BX23 and a 10 year old Toro Wheelhorse 38XL-14 that I use for mowing. I'm interested in getting a new mowing machine, but I can't make up my mind on what type to get. I will be mowing about an acre with some areas with moderate hills that I will be mowing across.. I was leaning toward a ZTR, but from what I've heard so far they are not the best for side hills. I am also strongly considering getting the XL Cyclone Rake, so that has to be taken into consideration in my decision. There are also some wooded areas where the Cyclones power vacuum pickup hose attachment would be terrific. There are a lot of flower gardens and tight areas in my lawn so I don't want anything bigger than a 44-46" deck. I also want to go to a better quality machine than the 'Bigbox" models, but I don't want to spend a fortune for a commercial unit. I originally liked the Toro ZX440 ZTR, but I heard they are not going to make them anymore. Can anyone confirm this? I am also considering the JD X304, which has 4 wheel steering, but I understand the transmission has been downgraded in the 2008 model. Since I will be towing the cyclone rake, that makes me a little nervous. So many choices, so much to learn. At least I'm not in a big hurry. The Toro is getting older, but it still works well. I mulch the grass, but bag the leaves, and it is a pain to have to empty the bagger so often, and with all the obstacles in the lawn it is difficult to get a pattern going. Every time I have a long straight run my wife wants to plant something in the way:D. Since I already have a BX23 the new machine will only be for mowing. I know I could get a belly mower for the BX23, but beside being too wide, taking the FEL & backhoe off every time to mow would get old really quick. I would appreciate input from people who have either of those units, or possibly other recommendations, and why. Thanks in advance.
Ken
   / Toro ZX440 ZTR or JD X304 4WS? #2
Hi,
Ken
I use these 2 in addition to my BX23.
http://i283.photobucket.com/albums/kk286/lb59/100_2316.jpg
http://i283.photobucket.com/albums/kk286/lb59/100_2313.jpg
A used one of these would be nice in your case or you might want to consider a CC GT 2500 or 3000 series.
   / Toro ZX440 ZTR or JD X304 4WS? #3
No good feedback for you but I am also interested in the JD X304.I will follow this thread. I am interested to where the the transmission change info is.
Good luck
   / Toro ZX440 ZTR or JD X304 4WS? #4
Don't know anything about those models. But, I do have a JD 425 AWS and I love it. Search for "AWS" in lawn and garden and you'll find a lot more about these machines. A ZTR will be faster if your ground is smooth and not too steep. But a tractor can do things, other than mow, more readily than a ZTR. In either case, steep hills call for a heavy machine.
Good luck
Munchie,
From what I understand the 08's have the k46 vs 07's having the k58.
2022 Case IH Steiger 420HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2019 HONDA PIONEER 5 1000 UTV (A50459)
2019 HONDA PIONEER...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A51039)
Kubota 24in Quick...
1974 Ih Farmall 1066 Tractor (A50514)
1974 Ih Farmall...
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
