torque for the oil drain bolt of a bx23
   / torque for the oil drain bolt of a bx23 #1
kubota35
york, pa
kubota bx23
first post to the website.......ready to change the oil for my BX23.....manual doesn't have actual torque value for the oil drain bolt.......I'd like to have that value and use my torque wrench if I knew what it was........any help???...thanks
   / torque for the oil drain bolt of a bx23 #2
Torque to yield.
Just joking, welcome to TBN. Do it like you would a car.........snug it good, then go a smidge more so it doesn't vibrate out.
Don, thanks for the fast response...........I'll "snug" it, but not too much...and of course, check for leaks...........thanks again...
   / torque for the oil drain bolt of a bx23 #4
Your welcome. Don't be a stranger.
Lot's of things goin on here on TBN.
   / torque for the oil drain bolt of a bx23 #5
Snug it up plus 1/4 turn.
AND, check the engine oil level and the hydraulic fluid level in the sump before starting the engine (do this every time--it's the cheapest engine/tranny protection).
   / torque for the oil drain bolt of a bx23 #6
Man.......that's a lot on a drain plug. I've never gone more than 1/8 of a turn.
But then again, maybe our definition of 'snug' is different:confused3:
EDIT: Some plugs have a course thread, some have fine........maybe that's the difference?
all, thanks for the advice.......have looked at this forum many times, but have not joined till now to actually participate............looks like I'll get some good answers.....
Mark
2016 Kenworth T270 Truck, VIN # 2NKHHM6X1GM110171 (A51572)
2016 Kenworth T270...
Fifth wheel multi use trailer. (A52748)
Fifth wheel multi...
Electric Parts Movers (A50121)
Electric Parts...
CFG Industrial STSD10 Grain Drill (A50121)
CFG Industrial...
2007 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2007 Ford F-150...
2020 Peterbilt 520 Truck (A51692)
2020 Peterbilt 520...
