Touching Up a JD Tractor
   / Touching Up a JD Tractor #1
DWCox
Northen Virginia
John Deere 790
I don't mind getting my tractor (JD) really dirty, or even scraping things up in the process of working. But I don't leave it in that state, since there is nothing more burdensome for me than to work on or maintain a dirty piece of equipment (or a dirty car for that matter).
I have a bit of time over Christmas break and thought I would do something I have never bothered to do in the past: touch up some of the small rust spots and areas of peeling paint. Do you guys just prep and clean these small areas and hit them with a couple light coats of oem spray paint, or do you buy the paint in quarts, and then dab it on with a tiny brush? Obviously I am not talking about high visibility areas like on top of the hood, but areas that are nonetheless visible and in need of rust correction.
Thanks for any input.
   / Touching Up a JD Tractor #2
Remove rust, maybe treat for corrosion, prime and spray. Spray cans are not that expensive and you can get them at TSC also.
   / Touching Up a JD Tractor #3
A small brush works great on any castings. You can't get a smooth finish on a casting no matter what you try.
   / Touching Up a JD Tractor #4
I know its lazy but I just pressure wash and hit it with the John Deere spray bomb
Thanks for the replies. The brush makes sense on castings, and I had already picked up a can of JD green from the dealer back in the summer.
It is funny, but I do believe with every tractor or piece of equipment I have ever owned, I have bought a can of oem touch-up paint with it, but never bothered using it.
   / Touching Up a JD Tractor #6
You can also get a touch-up paint pen in green or yellow.
Greentoybox.com::Green Paint Pen
2010 Ford F-750 Stellar 10621 10,000LB 5 Ton Crane Mechanics Truck (A51692)
2010 Ford F-750...
2016 INTERNATIONAL MA035 (A53843)
2016 INTERNATIONAL...
2007  BIG TEX 16' T/A TRASH TRAILER (A53843)
2007 BIG TEX 16'...
2020 KUBOTA RTV...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
AEROQUIP PROOF TESTER (A53843)
AEROQUIP PROOF...
