Tractor and Batwing shredder trailer size question.
   / Tractor and Batwing shredder trailer size question. #1
Jbird2020
Texas
All kinds
What size trailer are you all using to haul 100 hp tractor and 15 ft shredder?Im thinking a 36 ft .
   / Tractor and Batwing shredder trailer size question. #2
Pick up or semi? To me that seems like a awful lot of weight even in a 1 ton truck
   / Tractor and Batwing shredder trailer size question. #3
83hp tractor and 10 ft brushhog on a 25 ft gn. The weights and overall length would be much more helpful information.
Sorry Guys. I use a 1 ton . And as far as a tractor. It's a case 5240 but not sure on the shredder (I'm looking for one) . I've got to haul it 45 miles from one farm to another.I run the case on a 25ft trailer now. But it fills the trailer up good. I'm thinking the case weight is around 9500-10000 pounds.Im thinking the shredder weight Looking at 2000-3000 pounds.
   / Tractor and Batwing shredder trailer size question. #5
13k is no sweat for a GN. My deere weighs in somewhere around 10k with the loader, and loaded tires. I'd be looking for a 16k minimum and more likely a 20k GN. Length would be a minimum of the rig length plus 5'. If you pull the tractor on first, you are going to have ALOT of pin weight. I wouldn't be surprised if you had to haul this setup backwards.
   / Tractor and Batwing shredder trailer size question. #6
I did some measuring today to see what I needed for my tractors. My 130 hp tractor and 15' cutter would take more than 30'. My 50 hp and 12' would barely fit on a 25' if then. The cutter wasn't hooked and I didn't get an exact measurement. But either cutter is around 15' long.
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
John Deere Quick Hitch (A50121)
John Deere Quick...
2017 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A50323)
2017 GMC Sierra...
Moyno Sludge Pump (A50121)
Moyno Sludge Pump...
Military Winch (A50121)
Military Winch...
2023 FORD F-250 SUPER DUTY (A52472)
2023 FORD F-250...
