midwestbob2000
- Joined
- Jun 7, 2004
- Messages
- 4
O.K. my tractor is a Hinomoto C174 approx. a 1985 which I have now found is the same as an Allis Chalmers 5015 or a Deutz/Allis 5215. (I HAVE MANUALS ON THE WAY) I also have found that this tractor has a 12 volt system and not a 6 volt as I previously assumed.
I have been able to jump start the tractor by jumping directly from my car to the starter but if I run the jumper cables from my car to my tractor battery it will not jump start. (not evena click - just dead) I have check and cleaned the main battery cable terminals. I checked the battery cables and they look good however I have purchased new cables which I will install this weekend.
I have tried a new ignition switch which did not fix the problem.
I have found thru research that the recommended battery is 720 crank amps and 575 cold crank amps. However, I do not believe that this size battery will fit in the tractor as I have a U1 size battery area (small) currently with 360 crank amps and 300 cold crank amps. (Which is a stronger battery then what was in the tractor when I purchased it)
My turn signal lights which used to work no longer work. (The head lights do not work but never have worked) I have replaced all the fuses.
Please help, I am at a loss of what the problem could be. This is getting VERY frustrating!!!
