locknut
Platinum Member
- Joined
- Jul 31, 2006
- Messages
- 533
- Tractor
- Kubota
Seeing all those pickups and UTV's with those neat power angle v blades made me jealous,so I bought one and modified it to use on the GR.I bought a Cycle Country Snow Force UTV 72" unit and cut it down to 56" so it would V down to 49" to do sidewalks.I do a lot of walks around the neighborhood and they are old and really nasty with crack offsets over an inch high in many spots.With the factory straight blade it's easy as you go and constantly jamming the blade.
On the new V I fabricated a center bullnose angled up 30deg to an 1-1/2" height.I made a dry run and it works great,going over the bad spots like they are not even there.This should speed things up considerably.
Already had two high speed actuators on hand from the loader,so I used them with fabricated brackets on the outer ends of the blades,and the existing winch for raising/lowering.
The blade also has the bottom trip edge feature instead of the whole plow tipping forward.I tried it and it does work as advertized.
Here's some pics and a video from inside the cab:
v-blade pictures by locknut-1 - Photobucket
