Tractor loses power
   / Tractor loses power #1
fruitcakesa
Veteran Member
CavendishVT
M6040 JD 450C
Lately, when driving up slope, the engine will lose power to the point that in order to keep forward progress, I have to back off the throttle to maintain headway. As soon as it starts to level off, power returns.
Today, it also lost power on a downhill run and cleared up when back on the level.
I use freshly treated fuel with power service.
Any ideas?
   / Tractor loses power #3
Something floating in the tank that blocks the flow on inclines?
   / Tractor loses power #5
Try blowing out your fuel lines and see if anything changes.
Is there a glass bowl at the bottom of your fuel pump? Some of them have a screen, or brass like filter in them that needs to be cleaned periodically.
To turn off my small tractor, there is a solenoid that pushes a lever that cuts off the fuel to the engine at the injector pump. The solenoid wasn't retracting all the way, so I was getting full power because I wasn't getting all of the fuel that I was supposed to be getting. I bypassed the solenoid and put on an old fashion choke cable to open and close it manually. My power increase was significant and immediate. Before, I could barely climb up some hills while bush hogging. In fact, in those areas, I would work my way around so I was going down hill there instead of trying to mow up the hill. Now I fly along with tons of power, no matter if I'm going up or down a hill. It's like I got a brand new tractor!!!
I know that was a possibility but have not addressed that yet
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2003 International 4200 Box Truck (A51692)
2003 International...
UNUSED GOLD MOUNTAIN M122009 12'X20' STEEL CARPORT (A51248)
UNUSED GOLD...
2018 CATERPILLAR 320 LONG REACH EXCAVATOR (A51246)
2018 CATERPILLAR...
JD 1814E LOT IDENTIFIER 264 (A53084)
JD 1814E LOT...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
