rockbuster
- Joined
- Jul 21, 2008
- Messages
- 2
I have a 2003 Branson 2810 with 1100 hrs on it. Unfortunately the temp guage was not working for a couple of months and because it was running fine I ignored it until it overheated 2-3 times. I have fixed the temp guage (sending unit). Knowing that the guage did not cause the tractor to overheat I found the water pump to be bad so replaced it and the thermostat. Also flushed the radiator several times and obviously replaced all the coolant. The tractor seems to run fine now but runs hot. It does not over heat but will get up to the line. Not sure what to do next. No water in the oil or anything that I can see to indicate a warped head. ?? Any help is greatly appreciated. Thanx
