Tractor seems to use a lot of hydraulic oil
   / Tractor seems to use a lot of hydraulic oil #1
huntsmansix
My 2011 JD 5065E with loader (350 hours) is always very thirsty for Hy-Gard oil...I can't see any leaks?
I am (most obviously) not an expert so would be happy to hear any thoughts on this; I had to add about two gallons recently after a month or so of normal use....she runs great though?
Thank you!
   / Tractor seems to use a lot of hydraulic oil #2
Check your engine and make sure it's not going there.
   / Tractor seems to use a lot of hydraulic oil #3
I agree with checking the engine oil but not likely if you’ve lost 2 gallons. Does the tractor get parked on concrete?
   / Tractor seems to use a lot of hydraulic oil #4
While you are using it just keep an eye peeled for anything unusual. Loose hydro connections, trail of oil etc. Put some clean cardboard under it when you park it, might help locating something. .
   / Tractor seems to use a lot of hydraulic oil #5
Is the loader (and 3 point) only hydraulics used? No attaching remotes to anything?
   / Tractor seems to use a lot of hydraulic oil #6
Thank you!
I don't know about the HyGard oil but if it doesn't have a dye marker in it, you might want to add some. I use the red dye from Deere.
Part # MT3668. It sure makes it easier to spot leaks.
   / Tractor seems to use a lot of hydraulic oil #7
...also check steering lines
How would oil go in motor? At the pump?
Seems like 2 gallons in a month would show up somewhere.
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2017 Land Rover Discovery SUV (A51694)
2017 Land Rover...
Scag STT61V 61in Zero Turn Mower (A51694)
Scag STT61V 61in...
1266 (A50490)
1266 (A50490)
UNUSED FUTURE FT-B320 42" ROCK BUCKET (A51248)
UNUSED FUTURE...
2019 John Deere 5090R Tractor (A52384)
2019 John Deere...
