Tractor stopped, found water in diesel fuel, how bad is it?
   / Tractor stopped, found water in diesel fuel, how bad is it? #1
DCinVA
Fairfax, Va
Allis Chalmers
I started my Allis Chalmers 5015 diesel this morning, and as always it fired right up. It ran for about 3 minutes then started knocking, smoking and stalled. I tried to restart but it would not fire. It seemed like it was not getting fuel, so I pulled the fuel bowl and it was full of water, not just a little, but a lot. I cleaned out the bowl, and drained a tank until clean fuel came out, and put it all back together. It still would not start so I tried to bleed the lines to the injectors. I got some bubbles and a bit of fuel at #2, but nothing from #1 or #3. I am pretty sure that some water got into the injector pump. My question is, how bad is this, and where do I go from here? I am a little afraid to pull the pump apart, but that seems like that might be the next step.
Thanks in advance for any advise!
   / Tractor stopped, found water in diesel fuel, how bad is it? #2
Water can coat a fuel filter to where little/no fuel will pass through it. Install a new fuel filter if you haven't already done so.
Thanks Tx, I pulled the line downstream of the fuel bowl and filter and had good flow of diesel. I also cleaned the bowl and flushed out the filter. The filter will need to be replaced as soon as I can source one. I cranked it again and seemed to have a bit of flow from #2 and #3 but nothing yet from #1. I am concerned that the water may have damaged the pump, or the injectors. I will give it a rest tonight and look at it again in the morning. Sometimes leaving it alone for a while can help.
   / Tractor stopped, found water in diesel fuel, how bad is it? #4
I must have cranked my 7.3 Ford diesel van for an hour or two (just a few minutes at a time) until I got fuel flowing from the "cracked" injectors I could reach.
Took long time to get the air out.
Thanks to all for the help, special thanks to Harry in Ky who sent me a very helpful PM.
This morning I went out and hooked up the battery charger and let it run for a few hours.
Then I cranked it a bit with the injector lines loosened and had some seepage at #2 and #3. Still nothing from #1.
I tightened up the lines at #2 and #3, warmed up the glow plugs and tried to start it. It seemed to try to fire but would not catch. I let it rest for a few minutes and tried again. It eventually fired up but was only was running on #2 and #3. After a few minutes I noticed a bit of fuel leaking from the #1 line, so I stopped the engine and tightened the #1 line. I fired it back up and it was still only running on 2 cylinders, I let it run for about 5 minutes and eventually it started running on all 3 cylinders. Thankfully everything seems to be fine. I guess that the water that had gotten into the pump and injectors worked its way through and cleared.
The moral of this story is check your water separator on a regular basis. I was doing it annually and don't use the tractor that much, but perhaps it should be done twice a year.
Thanks again for all the support!
Dave in Virginia
   / Tractor stopped, found water in diesel fuel, how bad is it? #6
Good to hear that worked out for you.
If you haven't already, try and track down the water source - huge amounts in a separator are not normal.
If the tractor sits for a month or 3 at a time outdoors, then check the separator every time you fire it up.
Rgds, D.
2025 Kivel 48in Forks and Frame Tractor Loader Attachment (A46683)
2025 Kivel 48in...
2017 Chevrolet Impala Sedan (A46684)
2017 Chevrolet...
EZ Go Work Horse Cab 2-Seater Golf Cart (A44391)
EZ Go Work Horse...
2017 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A45676)
2017 KENWORTH T680...
2018 Dodge Grand Caravan SE (A46684)
2018 Dodge Grand...
2016 Freightliner M2 106 Crew Cab Palfinger Epsilon Forestry Grapple Truck (A46683)
2016 Freightliner...
