Tractor stops after a couple seconds
   / Tractor stops after a couple seconds #1
Nathandavis04
John Deere 5065E
My John Deere tractor currently has these codes and will drive about 10 feet before popping into neutral
PTR 524234.04
PTR 191.17
PTR 3509. 04
PTR 522456.31
CCU 100.04
CCU 3509.04
What do they mean
   / Tractor stops after a couple seconds #2
Welcome to TBN
Assume this is your JD 5065E.
Operators manual, or a service tech manual, or stop by the JD dealer. Otherwise, hope a TBN member will know the codes for that model and chime in.
   / Tractor stops after a couple seconds #3
You may be able to Google the codes too.
   / Tractor stops after a couple seconds #4
PTR 524234.04 is for transmission enable pressure sensor voltage low.
PTR 3509.04 is all transmission sensor voltage low. This is the same for CCU 3509.04.
PTR 191.17 is for transmission top shaft speed is too low.
PTR 522456.31 is for shifting without clutch, I wouldn’t worry with that code, every one I have ever checked has that code stored with no problem.
CCU 100 codes not listed in manual. Since there are several manuals depending on what your serial number is, I may be looking in wrong manual.
With the codes you have, I am guessing you either have a shorted sensor or wire somewhere. Also could possibly be a bad controller. CCU and PTR controllers are both contained in one Box. Have you tried clearing codes and see which ones come back after you try to drive? Some of these may be old codes stored from a previous problem.
   / Tractor stops after a couple seconds #5
PTR 524234.04
PTR 191.17
PTR 3509. 04
PTR 522456.31
CCU 100.04
CCU 3509.04
What do they mean
Having same issue did yo find your problem
   / Tractor stops after a couple seconds #6
Welcome to TBN
Do you have a 5065E? If not I highly recommend you start your own thread dedicated to your tractors model. Author of this thread had his last post on this site on May 5 so your chances for getting a reply from Nathan are ""nil to none"".
2007 John Deere 7930 4WD Tractor (A50860)
2007 John Deere...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
2006 Mobile Concepts Bumper Pull Trailer (A50860)
2006 Mobile...
UNUSED U Bolt Wire Rope Clamp Set (A50860)
UNUSED U Bolt Wire...
19009 (A48082)
19009 (A48082)
2012 Ledwell 130BBL Vacuum Trailer (A50860)
2012 Ledwell...
