Security & Theft Tractor Theft Tracking
   / Tractor Theft Tracking #1
lead_dog
Hi,
Is there a GPS based theft tracking system similar to LoJack that anyone would recommend for tractors?
   / Tractor Theft Tracking #2
How about LoJack? What's the difference between a tractor and a car when you're trying to find it?
   / Tractor Theft Tracking #3
There are a lot of large company's using LoJack on their equipment.
Look HERE
   / Tractor Theft Tracking #5
AbDaBu, Thanks a lot man! That is very interesting information. It is great to have competition to keep LOJAC from near monopoly status.
Years ago I designed a system for a private investor for security of off-site high dollar heavy equipment. It was not widely usable geographically since it relied on radio repeater coverage (radio coverage like paging systems) since satellite was too expensive at the time. With the proliferation of cell phone towers and ever improving coverage, cell phone based security systems should be getting practical and inexpensive. My premises monitored security system uses a cell phone backup module so if the bad guy cuts the phone lines the alarm system can still dial out.
There is a flaw in many of the anti theft devices. That flaw is in their methodology. IF proper operation of the anti-theft device is required for it to protect your asset it is not so useful. What happens if the bad guy smacks it with a hammer? A better way is to have the monitoring system store the last known location of the asset on a periodic basis (fairly often) and then if the device stops reporting its position you assume it has been destroyed and investigate using the last known location as a starting point.
Pat
   / Tractor Theft Tracking #6
There are several variations of this for tractor trailers, although it is secondary in the reasons it was designed.
Probabably first in use is Qualcom, a messaging system that monitors and records pretty much everything a truck does including speed/rpm/location and the time it happened. It is satelite based and is used by most of this countries trucking industry.
Highway Master is about the same thing, except cellular based.
Trailer Trac is a non messaging system for pinpointing trailer location. It tells location, empty or loaded and last movements, what truck hooked up to it and when. Unlike the others, it only updates once a day and has battery backup that lasts for about a month.
We had a trailer involved in a rail accident (not mine!!) and the railroad sent it to a scrapyard near our terminal. We finally sent someone to identify it as it showed being in a strange place with no activity and no record of one of our trucks moving it there. After figuring out what had happened, some of the shop guys went over there with sawzalls and cut the front of the trailer out to recover the unit.
David from jax
That's what I was looking for. The service monitoring is $20 per month, and it's too bad you have to change the batteries monthly. Otherwise, it'll do the job.
   / Tractor Theft Tracking #8
The heat and air outfit I use has the GPS connected monitors in the service trucks. An email is automatically sent to management with date, time, location, etc if the speed limit or management set speed is exceeded. A manager can log onto the web site and get all info, current and historical for that vehicle anytime. Cuts down on long lunches at the nudie bar.
Pat
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2021 Chevrolet...
2018 Ford Escape SE AWD SUV (A50324)
2018 Ford Escape...
2013 John Deere 160G LC Excavator (RIDE AND DRIVE) (A50774)
2013 John Deere...
2012 Freightliner Cascadia 113 Semi (A50514)
2012 Freightliner...
2011 CATERPILLAR 259B3 SKID STEER (A51242)
2011 CATERPILLAR...
2023 CATERPILLAR 299D3 XE SKID STEER (A51242)
2023 CATERPILLAR...
