Tractor weight
   / Tractor weight #1
pat32rf
Veteran Member
Bancroft, Ontario
JD4300
I am normally in the green and yellow forum but a young friend of mine has inherited a blue and white 1710 CUT with a 770B loader on it. He is parking it in my yard(out of sight) during the week so he can use it at his new woodlot/cottage down the road on the weekends.I told him that I would try to find out anything I could about this little work pony, such as HP, weight, age etc. Any one have any info they can share? Pat32rf (normally seen riding John) /forums/images/graemlins/grin.gif
   / Tractor weight #2
Here this should help you some.
Ford
1710
Manufactured: 1983 - 1986
Cost: (US Dollars) $8,859 (1986)
Power:
Drawbar (HP): 20
PTO (HP): 24
Engine:
Fuel: diesel
Cylinders: 3
Displacement (ci): 85.2
Compression:
Rated RPMs:
Torque (ft-lbs):
Firing order:
Oil capacity (qts):
Manufacturer: Shibura
Transmission:
Forward: 12
Reverse: 4
Capacity:
Fuel (Gal):
3-Point:
Category: I
Lift (lbs):
Power Take-off (PTO):
Type:
Speeds (RPM): 540
Tires:
Ag front: 5.00-15
Ag rear: 11.2-24
Dimensions:
Weight (pounds): 2470
Wheelbase (inches):
Length (inches):
Width (inches):
Height (inches):
2WD turn radius (feet):
4WD turn radius (feet):
Electrical:
Battery volts:
Ground:
Battery cold-cranking amps:
Alternator amps:
Serial Numbers:
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2008 CATERPILLAR 304C CR EXCAVATOR (A51242)
2008 CATERPILLAR...
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
Three Point Hitch Finish Mower (A48837)
Three Point Hitch...
2013 Ford Escape SUV (A50324)
2013 Ford Escape...
