Tractor will not move while in gear
   / Tractor will not move while in gear #1
tractordown
Hello everyone. I am new here. I just recently purchased a Mitsubishi 250D tractor. I was told that it was having clutch problems when I bought it. It wouldn't move while in gear. I was able to play with it and get it working enough to get it home. It finally quit completely. I had the clutch and release bearing replaced and resurfaced the pressure plate. After getting the tractor back it ran fine. All fluids in the transmission have been survived. I picked up the bush hog and engaged the PTO. After that it started doing the same thing again. When it's put in gear the tractor will not move. There was no grinding, no noise. Any help would be greatly appreciated!
   / Tractor will not move while in gear #2
Does the pto work? Will it move in the lowest gear?
Solved problem. The pin on the range control shifter was broken. This caused the gears to not engage. They were set in neutral the entire time.
   / Tractor will not move while in gear #4
Enjoy your tractor. My dad has had a MT250D for years now, and he really loves it.
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
UNUSED LANDHONOR PHA-16-2C HYD 3PT HITCH MOUNT (A54757)
UNUSED LANDHONOR...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
1998 ford f450 (A53422)
1998 ford f450...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
