Tractor won't stop with key.
   / Tractor won't stop with key. #1
brokeasajoke
Bronze Member
320dtc
Farmtrac 320dtc is the tractor I'm working on. Replaced the shut down solenoid a couple weeks ago after the same problem. Im back to manually moving the lever to shut it down. There is no power to the solenoid so I assume its the (t4340-60242) daedong time delay. Does anyone happen to know or have wiring info as to what or when its wires have power? I don't mind to replace it, I just hate to pay $70 for a part and still have the same problem and be back to square one. I also believe the part number is now superceded to end in 243 instead of 242.
Thanks.
After further inspection the fuse had a broken "leg". I read continuity measuring on the top of the fuse through the small hole on each side so I assumed all was ok. When I began pulling fuses one leg stayed in the holder bit the fuse bridge was still good. Odd. Never had that happen before. Cheap fix.
   / Tractor won't stop with key. #3
Glad you found the problem. (y)
   / Tractor won't stop with key. #4
My MF never shuts off with the key. I have to pull out that thing that looks like a choke. 😁:rolleyes::eek::alien:
E-Z Trail 680 Head Cart (A50514)
E-Z Trail 680 Head...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
JOHN DEERE 4100 TRACTOR (A51243)
JOHN DEERE 4100...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
2025 FREIGHTLINER M2 NON CDL BOX TRUCK (A51222)
2025 FREIGHTLINER...
2013 John Deere 310SK (A47384)
2013 John Deere...
