I would highly recommend a 20ft dual axle equipment trailer. I made the mistake of getting an 18ft'er and kick myself every time I load it up. This is a long machine with the loader and you can't get the tongue weight right on a shorter trailer. If you need to move it with rotary cutter a 22ft is necessary. Don't skimp on the weight rating either. These are heavy machines you are looking at 4500lbs plus implements. I would recommend a minimum of a 10,000lb trailer. They are usually good for 7500lbs of equipment. This puts you into a 3/4 ton truck for regular pulling. You can get away with some of the newer 1/2 ton trucks that are rated for 10,000lbs. Just make sure you have a tow package or equivalent and brake controller. I would also recommend a weight distributing especially if you are using a smaller truck. With the length and weight it makes for a much smoother tow. Good luck have fun an most of all be safe it's a lot of equipment to be dragging around.
