Kevin in OK
- Joined
- Dec 30, 2010
- Messages
- 2
I have been reading TBN for a long time, however this is my first post in the forums. I am considering purchasing a trailer for general use, but am having second thoughts. In the future I would like to haul an old tractor or two to a show. However right now, there is no reason for any equipment to leave the property, which makes me question the need for a trailer. Storage would be outdoors, possibly under a barn lean-to if it ever gets built. I guess what I'm trying to ask is should I get a trailer, and is the one I'm considering a good match for my (potential) needs?
Trailer in question is 18' pipe top utility, slide in ramps, 3500lb axles, brakes on rear axle (not hooked up, and no breakaway kit installed). May or may not need new wiring. It's a factory made trailer, but I couldn't find any information regarding manufacturer or the curb weight of the trailer. Where would I look for a data plate of some kind? Asking price is $1200.
Biggest tractor is a NH TT60A, about 4500 pounds. The 6' brush hog is 1200 lbs. This combination is probably 20' long. The old tractors mentioned above are a Ford 631 and a Ford 8n, 3300 and 2500 lbs respectively, each with or without a 5' brush hog at 500 pounds. No fluid filled tires or extra weights on any machine. Then there's the usual riding mowers, furniture, miscellaneous stuff that needs to go somewhere.
Here's the kicker. Tow vehicle is a 1997 F150 with 4.6L V8/auto. I can't find the GCWR, but the hitch I'm installing is rated for 5k, or 7.5k with WD hitch. It still needs a brake controller and the associated wiring, as well as probably a transmission cooler.
I'm pretty sure the TV is undersized for the NH/mower combo, but I think the trailer may hold it. Come to think of it, the NH alone would be a stretch for the truck, but if I ever get a larger truck would I have enough trailer? Both old Fords won't fit on the trailer at once, but either Ford/mower combo should be a good match with both the truck and trailer.
Anyways, your thoughts on all of this?
