Tram issue on 422
   / Tram issue on 422 #1
SwampmanLA
As anyone had a 4xx with hydraulic tram pedals just keep moving when you let off the pedals? My 2008 vintage 422 just started doing this, when I release the foot pedals it keeps rolling and slowly comes to a stop. Some opposite pedal pressure will stop the PT with no problem but the run on is new. I cleaned the muck out from under the floor boards, lubed the pedals up real good, but it still has run on. Tram still has plenty of power so I do not think it is a pump issue but a tram value issue. Ever heard of the tram valve failing on a 4xx PT?
   / Tram issue on 422 #2
Check your cable and the black round unit on the end of the cable at the tram.
   / Tram issue on 422 #4
Are there pedal return srings that may have popped out?
   / Tram issue on 422 #5
Is that pedal a spring to center valve or just a friction valve with spring assist?
   / Tram issue on 422
I talked toTerry and he asked me to reverse the two hoses from the pedals. I have been busy and have not had a chance to test it out. I will let you know what I find out.
   / Tram issue on 422 #7
my 425 has the same problem, cleaned debris out of forward/reverse tram valve, worked well for a while (20hrs) problem has resurfaced and intermittent, keep us posted what you find, check out post ''up a tree with the pt'' that was my rant. I have not had the time to investigate further the tram issue
   / Tram issue on 422 #9
it did not ''blow out debris'' on mine, it just reverses the direction the pedals work, forward pedal becomes reverse and vice versa :eek: just remember to switch the hoses back or possibly a week later while in a hurry you might forget (don't ask I won't tell)
   / Tram issue on 422
Finally had a chance to swap the lines on the 422 today. No joy, I still have the issue. Guess I'll see what Terry has for me tomorrow.
GARDNER DENVER 480 VOLT AIR COMPRESSOR (A50854)
GARDNER DENVER 480...
2018 Toro Sand Pro Bunker Rake (A49461)
2018 Toro Sand Pro...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2015 Dodge 5500 4X4 Bucket Truck (A51039)
2015 Dodge 5500...
LOT LOCATIONS (A51222)
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
