Trans Hydraulic Screen 2210D
   / Trans Hydraulic Screen 2210D #1
vongiese
NW Montana
Yanmar 2210D, Sany SY35 Excavator, Kubota 4060LE,
Think I've found the screen - but I can't get the cover plate off. Is it 3 screws facing the left side (if sitting on ractor)? I could not free this cover from the transmission. It is on the opposite side if the trasmission from a hydraulic line - when I took off this line I could look into a cylindrical "screen".
Maybe a little heat and a new o ring?
thanks - Happy Holidays!!
   / Trans Hydraulic Screen 2210D #2
I would not use heat .
Try a screw driver, or a flat end punch to remove it
try tapping it with a small hammer & pry it off gently
Heat might damage the housing around it or warp it.
Be careful, and it will pop right off
Ps . have a BIG pan underneath of it !
   / Trans Hydraulic Screen 2210D #3
Don't ask me how I know this, but it isn't too hard to break these caps. If it is cast, be careful. I'd tap on it a little with a small hammer, then take a putty knife and work it in around the edges (with the hammer if need be), then something slightly thicker, working it out evenly.
   / Trans Hydraulic Screen 2210D #4
PB Blaster...it's the answer to everything. And yes, I do put it on my oatmeal in the morning. Those caps are usually on with something resembling the hard drying permatex. Soak with PB overnight if possible, then do the thin screwdriver or chisel thing around the edges. More PB as you get ANY opening or separation. I have never broken one, but it can certainly be done. Prying is the way...just gently use that thin chisel to get under the edge.
Then clean both surfaces and put it back on with RTV silicone, so it's more easily removed next time.
   / Trans Hydraulic Screen 2210D #5
I just did one last week. The cover has a round lip that goes inside the main housing of the tractor. It has a slot and o ring.
If it is stuck, tap on the side of the housing so as to make it rotate, that will help break the hold on the round area. It isn't just a flat plate. It has to come out even and straight. And PB WILL cure everything.
Thanks for the help!!!!!
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2015 FREIGHTLINER...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2020 INTERNATIONAL...
1989 Chevrolet Corvette Passenger Car, VIN # 1G1YY318XK5111655 (A51572)
1989 Chevrolet...
2006 International 9400i (A52748)
2006 International...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A52748)
2012 JOHN DEERE...
