Trans range
   / Trans range #1
keep on tractorn
Case 275
I cant get my 275 to change out of high range. The handle wont move.
I just bought it.
   / Trans range #2
Welcome to TBN. Yours is a common "concern" with most new tractors. Be careful - don't push/pull so hard on that handle that you break something. Try shifting as you are VERY SLOWLY rolling backwards. Try shifting as you roll backwards with the tractor in neutral. Try shifting while rolling backwards with the tractor in 2WD.
With time and use it will loosen up. My M6040 is 14 years old. There are still times when changing range is difficult. Be patient - this will improve.
   / Trans range #3
Both my M9's act the same way and one has 4000 hours and the other 6000+. I have to rock the tractor or cut the wheels side to side to engage or disengage it.
2025 Wolverine CB-11-750F Concrete Breaker (A47484)
2025 Wolverine...
2020 GMC Sierra SLT 4x4 Crew Cab Pickup Truck (A44572)
2020 GMC Sierra...
4Yd Dumpster (A44571)
2025 LandHonor LHR-GAC40Y 2-Stage Air Compressor (A47484)
2025 LandHonor...
2025 KJ K1230 UNUSED (10) Wire Mesh Netting Rolls (A47484)
2025 KJ K1230...
2015 John Deere 4052R Utility Tractor (A44571)
2015 John Deere...
