Transmission Cooler for TC45D
   / Transmission Cooler for TC45D #1
cmoore20
2005 New Holland TC45D
Has anyone had problems with the nipple of the tranny cooler where the hoses attact to the cooler? Mine started leaking fluid and New Holland wanted $300.00 plus $80.00 for new hoses. They said the cooler had been changed and the hoses would not attach. I would up having mine re-welded, but there seems to be a problem with this.
   / Transmission Cooler for TC45D #2
I had one break on my old tc40d .The new part was revised and had a metal reinforcemnet washer around the base where the line met the cooler. I would have the parts guy at the dealer look up to see if they have the revised version of the part . And do a parts search for all of the dealers someone should one on the shelf somewhere.
   / Transmission Cooler for TC45D #3
I looked on the NH website they show two different part # for coolers for the TC45d . You will have to match the year and sn for yours. They have a break down for your whole tractor under the parts section for you to look up parts. I would hope they still make the part the tractor isnt that old .
   / Transmission Cooler for TC45D #4
Many people had a problem just as you with coolers made to a substandard design. It seems that the tractors most affected were built in 2003 to 2005, but I wouldn't swear to that. Mine was one of the well-built models and has never shown any signs of leakage.
The smaller Class II tractors have a problem with a coolant line that bursts and leaks, but this is different from our Class III tractors that had a weak adapter nipple on the cooler itself. Your repair by welding will probably last forever. If you search the NH Owning/Operating forum, you can find several instances of folks with HST cooler issues, both from the hose leaks and the cooler leaks.
   / Transmission Cooler for TC45D #5
any good radiator shop can fix it with no problem.
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
CATERPILLAR 301.5 EXCAVATOR (A51246)
CATERPILLAR 301.5...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
2025 Star EV Capella Electric Low speed Golf Cart (A51694)
2025 Star EV...
UNUSED RAYTREE RMDM725-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
