Transmission Oil / Gearbox Oil the same?
   / Transmission Oil / Gearbox Oil the same? #1
linearxs
Northeast Ohio
Kubota BX2660
I have a woods GTC40-2 tiller. The manual is pathetic for a newb like me. Is the transmission oil the same as the gearbox oil? Can I just pick one of the recommended oils below and use for both?
RECOMMENDED OIL
ESSO: Gear Oil CZ80 W/90
AGIP: F1 Rotra 80W/90
SH ELL: Dentax 90
MOBIL: Mobildue C90 TOT AL: FT 90
   / Transmission Oil / Gearbox Oil the same? #2
Yes it is the same on my tillers also. Just use any 80/90 weight gear oil and your good to go. On my tillers the same oil is used in both the gear box and side gears/chain case. I'm going to use Amsoil 75/90 on my Kuhn EL62 210. My manual said to "use synthetic if severe duty is anticipated".......oooooooookay. ESSO gear oil huh? I would guess the Woods is made in Italy and you might have a hard time finding those gear oil brands as I think they are all Euro brands that might not be over here. Good safe bet is go to your local JD dealer and get some JD "severe gear" 80/90wt and change it. I've found on my tillers that that first "factory" gear oil gets tiny "sparkles" in it from the gears wearing smooth on initial use. Good idea to change the side case and gearbox after about 20 hours of use.
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646718 (A51572)
2013 Dodge Charger...
2010 L3 MEP-806B GENERATOR (A52576)
2010 L3 MEP-806B...
2017 Ford Fiesta SE Sedan (A51694)
2017 Ford Fiesta...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
