Transmission strainer
   / Transmission strainer #1
bones72
Jd2210
Is there an easy way to remove rubber hose that lead to hydraulic strainer.removed two clamps and hose is tough to slide. After reading thread concerning debris in stainers,thought a good idea to check mine. Thanks
Bones72
   / Transmission strainer #2
Hoses tend get stuck pretty tight after a few years, try grabbing it with a big pair of channel locks and twisting it. Usually you can break one end loose at a time, and once it turns on the tube it's much easier to slide one way or the other. Once broken loose, use the pliers to twist back and forth while pushing in the direction you wish to move it. Usually works for me.
Thanks for help. Just got oil,etc and will tackle tomorrow. I am in northwestern Ontario and 4 hours from closest dealer
Bones72
King Kutter Rotary Tiller Tractor Attachment (A51691)
King Kutter Rotary...
2015 FREIGHTLINER CASCADIA DAYCAB (A52472)
2015 FREIGHTLINER...
2019 GEHL RT105 SKID STEER (A51246)
2019 GEHL RT105...
2013 INTERNATIONAL MA065 CAB AND CHASSIS (A52472)
2013 INTERNATIONAL...
2007 WABASH 53FT DRY VAN TRAILER (A52576)
2007 WABASH 53FT...
