trash/sewage pump design
   / trash/sewage pump design #1
lineman1954
sewanee TN
LS 4046 H
greetings, I have a LS 4640 with hydraulic ports, I am envisioning a hydraulic motor driven off the tractor ports running a trash/sludge pump, 3" in ( suction) and 3" out.....essentially, instead of buying a 7 or 8 hp gas pump, use the tractors hydraulics..... any help ?
   / trash/sewage pump design #2
How long are you going to pump for 1 or 2 hours? I would think it's cheaper to get a gas engine pump..
Less than an hour, I had a feeling someone would say that, it would be cheaper
   / trash/sewage pump design #4
I see those trash pumps on CL from 200 - 600 hundred bucks. I have 3'' trash pump that i put a new honda engine on..
   / trash/sewage pump design #5
Unless you're pumping for extended sessions plus . It's not worth it $$$ wise... Now if you don't want the aggravation of a small engine and $$$ to spare... Have at it .
   / trash/sewage pump design #7
What flow and pressure is available on your LS 4640? You need to know flow available at the quick disconnect not total tractor flow that includes power steering.
With this information you could then calculate size - displacement hydraulic motor you could operate at the required RPM.
Is using the PTO an option?
Great responses, Thank You All..after calculating all hoses and pump and attached sludge pump, I'm further ahead with a separate pump setup and gas stabilizer, for the once a year use...
   / trash/sewage pump design #9
Are you looking for a centrifugal pump or a diaphragm pump?
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50774)
STOP!!!! PLEASE...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2018 Ford Escape SE AWD SUV (A50324)
2018 Ford Escape...
2011 Chevrolet Equinox SUV (A50324)
2011 Chevrolet...
