Tread Cutting Oil
   / Tread Cutting Oil #1
s78wingrider
Hardy Co. WV
Mahindra 3215 gear
Sometimes hard to find what I need in this area. Anybody know something else I could use in place of tread cutting oil to tread a piece of aluminum? Thank You, Aaron
   / Tread Cutting Oil #2
I use most any light weight oil that is handy. 3 in 1 does good. Fluid film does well. Ken Sweet
   / Tread Cutting Oil #3
ditto that.. when cutting or drilling.. just about any oil will work... bar oil.. atf.. 10w30.. etc. the regularthread oil I use seems to be about a 30w or so.. o bar oil and similar work nice..
soundguy
   / Tread Cutting Oil #4
Add some kerosene to the oil. This will make a big difference when working with Aluminum.
MD3
   / Tread Cutting Oil #5
Look for a product called 'Rapid Tap'...it is readibly available on the Internet from numorous suppliers...it is a superior product for cutting soft metals
[Correction] the same company actually makes a product called 'A9'
Relton Chemicals specifically for aluminum
Relton Chemicals
   / Tread Cutting Oil
I have some Remington Gun Oil here with Teflon. I'm thinking of trying that :confused:
   / Tread Cutting Oil #7
Cutting and liberating oil are different, look at the names. If there were no difference there would be no need for anything special. I use cutting oil for plumbing, steel, copper, brass.
   / Tread Cutting Oil #8
S78wingrider, what size die are you using, and how many threads are you cutting? If you are only cutting a couple of smaller threads by hand, pretty much any oil will work, but if you are making many threads, and/or larger threads, you may want to use an oil similar to those already mentioned. My father used to tell me (many years ago), oil is cheaper than dies.
   / Tread Cutting Oil #9
I am not familiar with treading aluminum. Is it a forging operation?
larry
   / Tread Cutting Oil #10
Believe it or not, a squirt bottle filled with a 50/50 mix of liquid hand soap [dish soap OK] and water works great. I worked in a tooling/robot center back near the end of my work years, and that is what we used. Would not be any good for a machining operation where lots of holes are drilled/tapped in place for hours, but for the odd hole/thread it works just as good as store bought... It is fair with alu and copper and better than tapping oil [which is usually too thin] , years ago we used lanolin hand cleaner for alu/cu... You are not putting something on the drill or tap to lube anything. It is mostly for cooling and keeping the metal from sticking to the drill/tap and to helping the removed metal to 'flow' out away from where the real work is being done. [which you can call lube if you want]
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
2013 Big Tex 16GP-20 Gooseneck Trailer (A53117)
2013 Big Tex...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2017 Chevrolet...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2021 FREIGHTLINER...
