Tree Branch Mending
   / Tree Branch Mending #1
Pettrix
Platinum Member
High Desert Southwest
Had some destructive deer or maybe elk come through and they damaged a lead on my Maple tree.
The branch didn't break but was damaged and bent. Can one use something like duct tape or glue to mend/heal the branch or must it be cut off?
   / Tree Branch Mending #2
Yes, I hear you. Deer are all the time pulling down & breaking branches on my apple trees. Hard to tell if any repairs will save the lead but you have nothing to loose by trying. Use a type of tape that will breathe - not electrical or duct tape. Something like adhesive cloth tape - like you would use to tape up a wound. I've used elastic, sticky wrap that is used by vets to hold bandages on horses. Its open weave, sticky and elastic. Handle the lead as if it were a broken bone - I have put a length of quarter round molding on the limb and wrapped with the "horse bandage" material. Looks weird - but has saved major limbs many times.
Watch the "wound" area for any signs of drying out, bacterial infection, signs of spreading infection, etc. The damaged area is an opening to further infection and if this starts, I would remove the lead. There are products that can be painted on the damaged area to help healing - check with a local gardening center.
   / Tree Branch Mending #3
Yes it can be repaired, weather it should be might be open for debate. The damaged section can often be correctly positioned and then braced or splinted. Twine, rope, mesh cloth can all be used. Tape probably could be also. You will need to make sure that you do not stop bark growth or "choke" it. Rope can do that in the long term.
I will say keep a eye on it for good healing so your not dealing with a weakened section that comes back to annoy you later :)
Theirs lots of advice on the subject from googling "repairing broken limbs"
3032 (A46502)
3032 (A46502)
3069 (A46502)
3069 (A46502)
20ft Chain-Bottom Potato Box (A47369)
20ft Chain-Bottom...
2101 (A46502)
2101 (A46502)
KC 28in.x90in. Metal V Bottom Feed Bunk (A46502)
KC 28in.x90in...
2012 Chevrolet Cruze LS Sedan (A46684)
2012 Chevrolet...
