Trouble shifting a 790
   / Trouble shifting a 790 #1
Michigan_Mike
SE Michigan
Deere 790
Lately, when going from reverse to forward, my 790 doesn't want to shift, and I have to double clutch to get it into gear.
Are there any adjustments I can make to remedy this?
Thanks in advance.
Mike S.
   / Trouble shifting a 790 #2
Thanks in advance.
Mike S.
Any non-syncro transmission may experience that problem. Mine normally shifts easily from a forward gear to reverse...but occasionally, it sticks and requires a doubleclutch.
If this is an occasional thing, I'd say it's the nature of the beast. If all the time, you may need to adjust your clutch.
If the tractor is new, let your dealer do this.
Thanks Roy.
It doesn't happen all of the time, and it happens most often in the winter, so I won't worry about it. (at least until next winter.)
regards,
Mike S.
2019 MACK P164T WINCH TRUCK (A53843)
2019 MACK P164T...
Mohawk 12,000lb Two-Post Electric Auto Lift (A54811)
Mohawk 12,000lb...
2012 Infiniti G25 Sedan (A55758)
2012 Infiniti G25...
Toro Pro Sweep V4 Hydraulic Turf Sweeper (A55787)
Toro Pro Sweep V4...
Year: 2001 Make: Dodge Model: Ram Pickup Vehicle Type: Pickup Truck Mileage: 30413 Plate: Body Ty... (A55852)
Year: 2001 Make...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A53421)
2017 Toro Z-Master...
