Trouble shooting Lincoln ranger8 welder
   / Trouble shooting Lincoln ranger8 welder #1
Raul5452
Bronze Member
Corpus Christi Texas
John Deere 970, Kubota M7060
Need help , my Ranger 8 has quit. I've had it for 10/12 years. Regular maintenance on it. No problems until August 2017. After hurricane Harvey hit us I used it as a generator for about a week. Running 24/7 to power our refrigerator and freezer. On day 8 it was not putting out enough power to run refrigerator or freezer. I hooked up the welding leads and it barely creates a spark but will not burn the rod. Brushes didn't look that bad but I've replaced them with new ones. Still not working. Any help is greatly appreciated. Engine is running great.
   / Trouble shooting Lincoln ranger8 welder #2
Have you checked voltage with a meter?
   / Trouble shooting Lincoln ranger8 welder #3
Might want to post your problem over on weldingweb.com.
No RNeumann I have not checked voltage. Will this be across welding lead connectors ?
Neumann, no have not checked voltage. Will this be across welding connectors ?
Thank you Boomer I'll try welding web.
   / Trouble shooting Lincoln ranger8 welder #7
If it’s not putting out enough power to run frig I’d start on the 240v side. I assume that unit makes “standard” USA power which is split phase. So verify both phases have 120v. It sounds like you dropped a phase and or have a bad connection on one phase.
The welder, I assume, works the same as a shop welder. In that it drops voltage and increases amps from the “standard” 240v power. So checking that would be way “down stream” of what I assume is the root issue.
These are my assumptions having not worked on that machine. But I’ll go it on a limb and say you will find one phase is near normal at 120v and the other phase will be much lower.
   / Trouble shooting Lincoln ranger8 welder #8
Not sure if it applies to your welder BUT, some oder welder/generators had an "Exciter Wire" .
If it breaks or gets disconnected it will cause your problem.
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2014 TROXELL 130BBL VACUUM TRAILER (A52472)
2014 TROXELL...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2002 WESTERN STAR 4900 EX TANDEM AXLE SLEEPER TRUCK (A52577)
2002 WESTERN STAR...
2017 Rogator RG1300B Dry Fertilizer Applicator (A52748)
2017 Rogator...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
