Trouble with zetor
   / Trouble with zetor #1
dubster12
Having hydraulic problem . Got a 7745 with an aftermarket (allied ) loader . Have 2000lbs pressure at the valve . Cylinders are rebuilt so is valves will pick up bucket empty but not with a load .Ive tried everything . Any ideas. Its got 14 gallons of fluid cant imagine that not being enough. Over half way up the stick .
   / Trouble with zetor #2
I"m not an allied loader guy, but most loaders have a pressure relief valve that limits the lift capacity, yours may be out of adjustment (you mention rebuilding the valve). the valve is adjusted to kick off at a certain pressure.
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
2019 Bobcat T770 Two Speed Compact Track Loader Skid Steer (A50322)
2019 Bobcat T770...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
Ford Super Duty 8ft. Truck Bed (A48081)
Ford Super Duty...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
