Troubles resolved, thanks TBN
   / Troubles resolved, thanks TBN #1
Fanlo2300
Quebec Canada
Case IH DX33
I just bought a 2003 DX33 last month, and I have been enjoying it a lot since.
I came to TBN to learn, and I am glad I did.
I have read a lot about tractors not starting, and hydraulic hoses bursting on DX33 and TC33, but I thought my tractor was immune... until last week-end.
On Saturday, after a few hours wood chipping (Bear Cat on PTO), I stopped for lunch. After an hour, the DX33 would not start. All safety swithces where ok, so I took a look at the fuse box and quickly found the 10 amp fuse blown. Replaced it and engine started immediately. Thank You TBN
The following day, I hooked the 60" rotary cutter and proceeded to mow some tall grass. After an hour or so, I smelled something was wrong. Stopped the tractor and had a look around: hydraulic fluid was dripping on the front axle. Opened hood and WOW! the engine was soaked... Had enough fluid remaining to get back to the house. The elbow hose under the hydraulic fluid cooler was cracked, as was expected... I got replacement at the NH dealer (modification kit was not in stock: will get it next time the hoses need replacement).
I took the opportunity to replace both hydraulic filters (took care to buy the "winter" model, as recommended on TBN).
Il will continue to read TBN for sure, because what I learned already saved me a lot of money identifying these troubles.
   / Troubles resolved, thanks TBN #2
lotsa good people here!
soundguy
   / Troubles resolved, thanks TBN #3
Welcome and so glad TBN came thru for you.....congrats on reading and discovering prior posts/comments/solutions.... :thumbsup:
   / Troubles resolved, thanks TBN #4
welcome to TBN blue. There many good people with a life of experience that sure like to share when asked. Glad you got your problems fixed.
JC,:)
   / Troubles resolved, thanks TBN #5
Well there you go! We blue New Holland owners are not only willing to help each other, but we help our "red-headed" siblings as well.;) Congrats on your fixes Fanlo.:thumbsup: Let's hope that you don't have anymore problems, but if I were a betting man, I'd bet you will continue to have the fuse blow from time-to-time until you replace it with a self-resetting circuit breaker. They are available at auto parts stores here, but I'm not sure what store would have them in Canada.
2006 Toyota Tundra 4X4 Pickup Truck (A53424)
2006 Toyota Tundra...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A52706)
UNUSED AGT YSRT14...
2014 CATERPILLAR 336EL EXCAVATOR (A52705)
2014 CATERPILLAR...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
1992 MACK RD688S (A53843)
1992 MACK RD688S...
