Try Calling a Hardware box store and asking if they have Sling for Weeds
   / Try Calling a Hardware box store and asking if they have Sling for Weeds #81
Probably the best HOE I have used was one of my Sisters, which was more of a Elongated Pentagon/Diamond shape. It came to a some what sharp point with about 3" long flats that got wider (about 3" wide) at the 3" high point and was squared off to about 4 or 5" total height.
It was real good for those long rooted plants and you turned it 45 degrees to hoe flat spots or hold it straight up and make a planting row. tilting it left or right was depending on which side of plant or left/right handed. the tips were wor off to almost rounded about 1/2" radius.
She had a 2nd one which was similar but was only about 2" wide and it had a dual tine that came off the back of the hoe, 3' pointed on one side and back side was dual 3" points in a "V" shape. both sides were used one for planting weeding & other side for covering seeds or weeding both sides of small plants or breaking up ground.
both of which were well warn & often sharpened with FILE with grinder stone used some times. I still have 1/2 of one with a broken handle that I should fix someday...
Mark
   / Try Calling a Hardware box store and asking if they have Sling for Weeds #82
Talking about hoes,, I got my hoe down and let me tell you, my hoe and I smoked some weeds today. My hoe was big headed hoe also, I had to cut that hoe head down, nobody likes a big headed hoe, cause it just won稚 fit around the small stuff, Now that hoe will fit around anything smallest to the biggest stem. A man needs a good hoe if youæ±*e going to grow things that need to be cut. Thatç—´ why I take care of my hoe. I like to hose that hoe down at night and hang it up to dry. So it will be nice and clean for next time, sometimes I file that hoe, so it will stay sharp, nothing worse than a dull hoe. You may have a hoe story to tell, feel free to talk about your hoe if you would like, cause down deep,, all gardeners like a good hoe story when gardening around.:laughing: Lou
There are two varieties of hoe.......one is a gardening tool....the other is a hardening tool!:thumbsup:
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2001 CATERPILLAR 908 LOADER (A51406)
2001 CATERPILLAR...
2025 Auger Mini Skid Steer Attachment (A53421)
2025 Auger Mini...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A52706)
UNUSED AGT YSRT14...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A54811)
2019 Caterpillar...
