TS110 Serpentine belt splitting
   / TS110 Serpentine belt splitting #1
crbearden
Belarus 825 & 8345, NH TS110, JD 4010 LP & Dsl, White 2-105, Oliver 1850, Ford 5000 dsl, MF 65 LP x 2 , JD 410 BACKHOE, CAT 112B Hoe, CAT 944 Loader, CAT 613 scraper, Cat D6 Dozer, Case 1150 Dozer, Case 930 Dsl, Case 930 LP,
Replaced Water pump about 16 hours ago re-used old belt.. After about 14 hours of operation the serpbntine belt split in half. I replaced the belt and the grooved idle, replacement idler was plastic. After another 2 hours of operation the new belt split in half and jumped off. The replacement idler was looser than the original one. I found a steel grooved idler and am replacing everything including tensioner and flat idler. Any ideas as to what else could be wrong. Loader is back on tractor, so removing radiator and everythign is not a fun chore...
Toro 30672 32in Walk-Behind Mower (A44572)
Toro 30672 32in...
2025 Wolverine ADB-13-1218R Auger Attachment (A47484)
2025 Wolverine...
Front Weights & Spacers for international 5088 (A47484)
Front Weights &...
Swict 66in Bucket Skid Steer Attachment (A44571)
Swict 66in Bucket...
2007 Kubota RTV (A45336)
2007 Kubota RTV...
2025 Wolverine...
