TS16/1910 bumper
   / TS16/1910 bumper #1
Ron25
Bronze Member
Can someone tell me the size of the flat bar (1/4x2.5 .. 3/8x3 .. ?) used for the front bumper on the 1910. Mine had a cage built in place of the original and I want to get back to what was on there.
   / TS16/1910 bumper #2
i have a 2205, expect that it is the same?
   / TS16/1910 bumper #3
I wouldn't put all my money on it, but I suspect these will all be the same. The flat bar is to hang "suitcase" style weights (at least, that's what they are called here in Australia) they would want to be universal.
   / TS16/1910 bumper #5
Is it the bar in the attached picture, where the front weights are?
  • TS1610 Front.pdf
   / TS16/1910 bumper
Yes rich - measure that for me. Looks like 3/8x2.5 or 3. Metric likely has it somewhere in the middle. Where it bolts to the frame is that area undercut smaller than the bumper front? On mine if it's 3", it seems the pivoting of the axle could hit it.
Also, how wide is it across the front .. looks about 16/18". And while your at it .. lol .. check the distance from the frame to the bumper front.
Thanks a bunch!
RonB
   / TS16/1910 bumper #7
Ron, I just went out to the shed and measured my TS1610 bumper.
3"high x 3/8"thick x 16" across (side to side). The sides are approx. 3-1/2" wide and bend at about 60-deg. back to the frame where they are welded to the sides of the frame rails. The front face of the bumper projects about 7" from the front end of the frame rails. Hope this finally answers your questions.
Bill
   / TS16/1910 bumper
Thanks Bill. I didn't know it was welded, on mine there are two bolt holes on both sides with nuts tacked on the inside frame.
   / TS16/1910 bumper #10
Mine is also welded. Attached is are pictures showing this.
  • TS1610 Bumper.pdf
  • TS1610 Bumper Front View.pdf
   / TS16/1910 bumper
humm - what are those holes for? I thought that is where it mounted and was going to go back farther than needed. That's why I asked about the bar hitting the axle. Thanks for the pic rich.
2014 FORREST RIVER SALEM TRAVEL TRAILER (A58214)
2014 FORREST RIVER...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2015 KOMATSU WA270-7 WHEEL LOADER (A60429)
2015 KOMATSU...
