TSC Carryall
/ TSC Carryall #1
Benja
Sorry if this post doesn't make sense, my wife is talking while I'm trying to type.
My recently purchased carryall has a one inch diam. hole for the top link and my Bota B2410 has a 3/4 diam hitch pin that snugly fits in the top link arm.
Is there an attachment needed to mate the two or is the 3/4 inch rod allowed to float inside the larger hole?
/ TSC Carryall #2
It can float or you can buy some $1 bushings at TSC. That gives you an excuse to go back and some more goodies.
/ TSC Carryall #3
I find it surprising that TSC would carry a Cat 2 carryall. Unless that hole was overbored by mistake, the lift pins should be too big for your little Kubota as well. Back to the top hole though - I would use bushings to avoid egging out the hole. But then maybe you don't carry the weight that I do on mine - which I got at Rural King by the way. It's got a 3/4" hole, so I don't need bushings.
If it's simply overbored by mistake, TSC won't likely have a bushing for that situation. What you could do though is find a short piece of 3/4" ID steel pipe. It will have a 1" OD. Cut a section of pipe that is long enough to go through both holes on the carryall, then slide your toplink pin through it.
//greg//
/ TSC Carryall #4
The red Carry All I purchased at TSC over 5 years ago also has a 1" hole for the top link. Hasn't bothered me a bit being a little sloppy. Makes it easier to hook it up :)
Gem Electric 6-Seater Cart (A61166)
Gem Electric...
New/Unused Agrotk YC-32G Sawmill (A61166)
New/Unused Agrotk...
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A62130)
UNUSED SDLANCH...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2012 Freightliner M2 112 Fuel and Lube Truck, VIN # 1FUGC5DV5CHBF7397 (A61165)
2012 Freightliner...
2021 John Deere 6110M Tractor (A63109)
2021 John Deere...
