Turbo Boost Gauge
/ Turbo Boost Gauge #1
rScotty
Super Member
Rural mountains - Colorado
Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Has anyone mounted a boost gauge on their Kubota? Or do any of the models come with one? What pressure? Any mounting tricks?
I used to enjoy listening to the turbo boosting up on the old JD 4010. The new KubotaM59 turbo is way quieter and doesn't have that JD turbo whine.....a suppose a gauge isn't necessary, but it would be one more toy that is fun to watch.
rScotty
/ Turbo Boost Gauge #2
It should be easy enough to install, a 30 psi gauge mounted on the dash and a small brake-size braided line running to the intake manifold would do the trick.
Chilly
/ Turbo Boost Gauge #3
rScotty
Unless your old JD 4010 had a M&W turbo kit installed the 4010's were naturally aspirated.:D Any boost gauge up to 30 psi should work fine.
2007 Mack CTP713 Wet Kit T/A Day Cab Truck Tractor (A64194)
2007 Mack CTP713...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
John Deere 400 Rotary Hoe (A66408)
John Deere 400...
Sunflower Yard Art (A64557)
Sunflower Yard Art...
100-gallon L-shaped Split Fuel Tank (A66408)
100-gallon...
New/ Unused Landhonor 2 Stage Air Compressor (A65583)
New/ Unused...
