Turn Signal/Flasher
   / Turn Signal/Flasher #1
Dave2610D
Bronze Member
Breaux Bridge
Yanmar 2610D
.Is it possible to change out my left/right turn signal switch and install a three position switch to create a turn signal/flasher type of set up and still use my two prong relay? Will I have to change that and if so what type or prong count.....do I have to do any other wiring? Thanks
   / Turn Signal/Flasher #2
This is most elemental turn signal system.... Yes you can ignore the pilot lamp (dash lamp) of three prong flasher and use a two prong flasher if you wish...
Concept of "early" thermal type flashers....
Switch should be a single pole "ON-OFF-ON" type...
The designation on flasher pins may be different as to what particular manufacturer chose to designate them as... New flashers may even use DIN numbers as designations...
You may also to consider "electronic" flasher as rate will be consistent no matter if you flash incandescent bulbs or LEDS or 1 or many bulbs...
Dale
2000 Ford F-450 Auto Crane 6006H 6,000LB Crane Service Truck (A48081)
2000 Ford F-450...
2003 Ford F-450 Knapheide Enclosed Service Truck (A48081)
2003 Ford F-450...
2015 Ford Taurus AWD Sedan (A48082)
2015 Ford Taurus...
2018 DODGE GRAND CARAVAN (A51222)
2018 DODGE GRAND...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2018 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A51222)
2018 INTERNATIONAL...
