TYM 394 hst won’t go into gear went to change transmission fluid and 5 bolt came out of drain plug
   / TYM 394 hst won’t go into gear went to change transmission fluid and 5 bolt came out of drain plug #1
Tkeb560
TYM 394 hst 2018
   / TYM 394 hst won’t go into gear went to change transmission fluid and 5 bolt came out of drain plug #2
Oh man, at least it looks like you are still under warranty? Can't say I've seen that before on that chassis.
   / TYM 394 hst won’t go into gear went to change transmission fluid and 5 bolt came out of drain plug #3
Take it to dealer if you're still under 6y powertrain warranty?
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
1999 Case 602B Vibromax Sheeps Foot Roller (A59213)
1999 Case 602B...
3pt 4' Box Blade (A57149)
3pt 4' Box Blade...
2002 Isuzu NPR-HD 14ft. Box Truck (A56858)
2002 Isuzu NPR-HD...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
