U-Joints & Yokes for FEL Pump drive?
   / U-Joints & Yokes for FEL Pump drive? #1
Ehanson
Kamloops, B.C.
S373-D
Hi , just wondering if any one has tried to purchase the 2" Ujoints/Yoke assy to make their own pump drive shaft?
The smallest swing from spicer, etc is 2.5 which makes it real close to the bottom tank of the radiator. I think the machine shop called it series 1000.
Any one? , I posted in repair forum, but no replies, perhaps someone here?
Thank you
   / U-Joints & Yokes for FEL Pump drive? #2
I'd check a supplier dedicated to bearings seals and such. Around here that is Mcquire bearing...they might be able to match something by measurements. Maybe they'd have other solutions as well.
Do you have a pict of the original set up?
   / U-Joints & Yokes for FEL Pump drive? #3
Don't laugh but I have seen short lengths of hydraulic hose used to create flexible couplings.
2 braided of suitable ID to match shafts works fairly well. Naturally the hose and shaft need to be drilled to accept a bolt and some shaped clamps made up. A short piece of thick tubing of proper ID to match hose OD would work. Slit the tubing clamps lengthwise B4 clamping.
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A55218)
2022 NEW HOLLAND...
3 PT QUICK HITCH (A54756)
3 PT QUICK HITCH...
UNUSED IRANCH 1R EXCAVATOR RIPPER (A54757)
UNUSED IRANCH 1R...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XLT...
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
